Nikki's yellow throwback Jeep
The thimble mount, yes. How are the guides that the thimble is against attached to the fairlead mount.
I just removed them from the TRE thimble fairlead and installed a standard TRE fairlead, lined them up with the angles of the standard fairlead and drilled and mounted them
The fact that Mopar has discontinued the camshaft position sensor for my jeep has me a little worried after having dealt with the struggles it and the crankshaft position sensor caused me. Mopar still has crankshaft position sensors out there that ship from dealerships and known overstock sites (not sure that means anything) but not knowing if there’s a camshaft position sensor brand out there that works has me searching because I don’t want to be caught away from home when a sensor goes bad again. So I ordered a WVE brand sensor from Rockauto. On Rockauto it was the only brand of sensor that had noted a verified temperature rating of -40 to 300 degrees. Temps were causing the issue with my new “faux-par” sensors. It also appears WVE is owned or associated in some way with NGK/NTK which makes the o2 sensors that like to play nice with our jeeps. It says made in China but I haven’t found one made anywhere else. I’ll continue to run my original Mopar one until it no longer functions but I’ll test out this sensor this weekend and report back.
That is a very well behaved rig. People really need to appreciate what is going on (and what isn't).
I’m extremely fortunate to be so close to someone with so much knowledge of how these jeeps of ours work. I know very few people who actually own their dream vehicles. Thanks for noticing and acknowledging.
There is a lot (not) happening that would frustrate the geometry correction guys. 🤫
