Made some homemade bump stop extensions. Drilled and tapped a hole in the perch then drilled out hockey pucks and countersunk the bolt using a forstener bit.
Fix it before you cover it or it will come back to haunt you! Great looking TJ!!
Yeah I’ll definitely fix it first, I’m hoping the bondo doesn’t go so far up that it makes it so I can’t bolt on sliders, it seemed to go up pretty high form the magnet test. And thanks!
