First Post/Thread Disclaimer (proceed at your own risk):
~~~ Purchase Date: 2021.02.09 ~~~
~~~ Latest Update: 2021.04.08 ~~~
Bought a 98 TJ off my brother and I'm fixing it up. She has 130k miles and was initially babied as a high school starter vehicle (x2) with <6k miles per year, but sat over the last year when my brother got a new daily driver. I believe the only mods are a 1.5” body level + 1.5” spacers all around, but the rest is stock.
I'm stripping it down, going to replace most everything under the hood, and raptor line all the red paint while everything is stripped out - going to be a ranch vehicle & no paint will survive a few weekends in the mesquite without Ceramic Pro or some other expensive junk.
I'm a first-time TJ owner, so this is all new to me.
I'm pretty comfortable working on vehicles (mostly chevy/dodge trucks so far, but I've taken to it pretty quickly) and I'm excited to learn more because owning a half-door TJ has always been a dream of mine.
With that said, I have so much to learn and any help/comments are much appreciated... thanks in advance y'all, this seems like a great group already in the few posts I've read.
Completed Items
Upcoming Items
Before I drove it back to my house...
- New Oil & Filter (runs okay, but can't diagnose an annoying 1st gear rattle in 2WD, goes away in 4WD, could just be loose gearbox)
- Optima Red Top
- Remove aftermarket speakers on the roll cage and pull the wire that kept grounding out.
- Remove seats, roll bar covers that are worn and tattered.
- Pull center console and seats
- Pull fenders
Raptor Lining Prep (Sand & Priming)
- Fender flares going to the dump, no-one wants them...
- Bust off old bolts/drill out sheared ones
- Sand interior to 40/60/80 grit
- Blast removal (60-90 grit) on any hard-to-reach rusted component (e-brake, etc.)
- The portable blaster is really useful for nooks & crannies that you can't get to the blast cabinet
- Por-15 Rust Prep on minor rust spots
- Pop dents, Bondo filler on what can't be popped.
DIY Raptor Lining (Mesquite-Proofing)
- Disassemble Doors & Dash, blast and tape dash off
- Raptor Lining (I'll probably catch hell for this but you should see my truck... I don't want to deal with the scratches anymore... ha!!!)
- Hit with wire cutting tape (this stuff works really well underneath painter's tape...
- Interior: Desert Tan
- Exterior: OD Green
- Engine Bay: Black/Tan
- Pull Tailgate, Hood, Doors & disassemble for separate spraying
- Bust out old bolts, new bolt kits from Jeep Bolts, where needed...
Under the Hood Upgrades
- Upgraded Starter/Alternator to keep up with higher output electrical
- Mopar Starter
- MOPAR 117A Alternator was out of stock everywhere I checked
- Update: the Durango 160A Alternator didn't fit my bracket even remotely
- New Spark Plugs + Wire/Tune-Up Kit with Boot
- New NGK Ignition Coils
- New Sensors
- 02 Sensors (thanks @Chris )
- Crankshaft Position
- Doing this super helpful Cooling Overhaul (thanks @Chris )
Exterior Parts
- Barricade Fender Flares
- Barricade Rock Sliders
- Steering Box Skid Plate
- Barricade QD Rectangular Mirrors
- Rough Country Hydraulic Hood Assist
TBD Under the Hood other items...
- Flush & Swap Fluids (leaving towards the end)
- Brake Lines
- Power Steering
- Transfer Case/Transmission/Rear Diff
- Including New Gaskets
- Potentially new internals if it's too chunky (fingers crossed)
- A/C Accumulator got this for $5 on RockAuto, but I don't have the refrigeration equipment to do the vacuum work so I'm tabling this for now...
TBD Welding & Metalwork
- Weld-In back seat brackets onto floor/fender with 1.5" angle L iron lower seat, making the back seat bench rear-facing and setting the top of new trunk storage
- Weld-in 1/4" plate across fender wells
- Weld-/Bolt- in a rear toolbox underneath rear seats
- Weld-on rigid molle panel for gun storage, etc. between rear seats and front seats
- New Hinges from JeepBolts.com
- New Brackets for Lightbars (see the last section)
TBD Other Exterior & Body Work
- Smittybilt SRC Front Stinger Bumper
- RedRock 4x4 Rock Crawler Rear Bumper w/ Tire Carrier
- Mammoth D Window Black Wagon Wheel 15x8 Wheels
- New Tires (leaning Mickey Thompson Baja Pro XS), size depending on lift, etc.
- Skid Row Offroad Radiator Guard
- Rugged Ridge Off-Road Jack Hood Mounting Bracket
- Angry Eyes Matte Black Headlight Conversion
Electrical..................
- Auxillary Battery Setup (see attachment/below for my initial wiring diagram draft)
- Second Optima Yellow-Top
- SmittyBilt Dual Battery Tray
- Isolator/Fuse Panel
- Secondary Fuse Panel
- 200A Inline Breakers, etc...
- IF YOU'RE FAIRLY NEW TO AUXILIARY FUSE BOXES, THIS IS A GREAT VIDEO TUTORIAL
- RC Pro Series Winch (9,500 lbs) — thanks @Jimmydidit23
- LiteDOTs LED Tail Lights
- Axial LED Daymaker Headlights
- 40" Curved CREE LED Overhead Front Bar
- (4) 10" CREE LED Side Bars Above all 4 fenders
- Still looking into a PA System potentially
- Looking into a HAM radio dash kit/whip antenna (50/50 here)
Uncharted waters(I haven't done any of this work, but looking for parts & recommendations, probably a third party here)
- Looking into 4" Teraflex lift or maybe a long-arm depending on how the paychecks look this year — HA!
- Drivetrain
- Axles
- Front: Dana 30/186
- Rear: 175mm w/ 3.07 Ratio
- Differentials
- Drive Shaft Check
- Transfer Case
- U-Joint
- Axles
- Suspension (Currently Normal Duty, wanting to upgrade)
- Springs
- Shocks
- Struts
- Stabilizer Bar
Thanks again for any advice here y'all — just joined in February so looking forward to the next year or so of building it out. Will keep this updated once I figure out how these threads work, etc.
- Fletcher
