Please have this man banned... There is no room in this tread for happiness and joy.Got some good shipping news. My beadlocks scheduled for Thursday delivery have been switched to tomorrow. UPS maybe coming early!!!
You need that classic bumper sticker: <——--Passing side | Suicide-——>We turn semis off the highway into narrow drives. Say a right had turn, signal right but have to get the semi in the left lane. Prefer this maneuver with no one behind me but one of three things happens:
Signal right: car passes immediately on the left. 40%
Signal right and see the car slowing behind. I creep over into the left lane, then the car passes on the right (just before I start my Right turn) 10%
Signal right, car backs off, let’s me turn w/o issue! Surprisingly about 50% do what they’re supposed to.
Ha, they were delivered yesterday also!!!!!!!Please have this man banned... There is no room in this tread for happiness and joy.
Oh, by far, but I don't understand why any philips head wood screw over an inch is manufactured. Holy hell, the constant cam-out right before you can sink it properly drives me batshit.They're better than flat heads
I always feel like a turd when I see a semi try to make a tight turn right after I can no longer move out of the way to help. Sometimes, the person behind me will realize what's going on and try to get out of my way so I can get out of the semi's way.We turn semis off the highway into narrow drives. Say a right had turn, signal right but have to get the semi in the left lane. Prefer this maneuver with no one behind me but one of three things happens:
Been there, felt that! I had to rehang some cabinets and instead of reusing the shitty 3" long philips head screws that were in it, I went and bought some torx just to avoid that problem.Oh, by far, but I don't understand why any philips head wood screw over an inch is manufactured. Holy hell, the constant cam-out right before you can sink it properly drives me batshit.
Square drive can be pretty good too.Been there, felt that! I had to rehang some cabinets and instead of reusing the shitty 3" long philips head screws that were in it, I went and bought some torx just to avoid that problem.
I get it. I drive in SF Chinatown and the Bay Area in them.We turn semis off the highway into narrow drives. Say a right had turn, signal right but have to get the semi in the left lane. Prefer this maneuver with no one behind me but one of three things happens:
You probably won't have to rework your cabinets for a while, but Kreg makes awesome cabinet screws. I found them while researching pocket hole jigs while trying to dress up the steel I-beam in my basement with a wood facade.Been there, felt that! I had to rehang some cabinets and instead of reusing the shitty 3" long philips head screws that were in it, I went and bought some torx just to avoid that problem.
Beat me to it re:JIS. I bought a set of JIS screw drivers for my Honda. Then pulled all the JIS head screws and replaced them with Allan head but I didn't go stainless.When I bought this thing in 2006 the forums were aflame in complaints about the garbage phillips screws Suzuki used everywhere that stripped out if you looked at them wrong. And because many of them were steel screws into aluminum (like the carb bowl that we all removed on day 1 to rejet for our aftermarket exhausts and airbox mods), they already required a baffling amount of torque to break free on brand new bikes. Fortunately none were countersunk so they all came out ok with vice grips.
Then some smarty-pants got on and posted about Japan having their own Japanese Industrial Specification (JIS) interpretation of what we call Phillips head, but the cam-out dimensions were slightly different in such a way that American screwdrivers stripped them out. If you used the screwdriver that came in the toolkit (that we all promptly removed from the rear fender because it looks dorky), they came out for the most part without stripping. Of course by that point I'd replaced almost all of them with stainless hex socket head screws.
All true - coat the fastener with copper based never-seize or grease. Both will sharply mitigate the corrosion - we ran 316 stainless bolts into bare aluminum on seagoing equipment that was in the "splash zone" for *years*. We'd use Delrin bushings when we could, but when we couldn't, we used a very tacky grease called "Aqua-Lube". I won't say we didn't have corrosion, we did, but it was minimal and things would last for a decade or more.it did keep them looking nice, but I know more about galvanic corrosion now than I did back then, so I wouldn't do stainless again. Stainless steel is farther from aluminum than carbon steel is in the galvanic series, so stainless into aluminum would have accelerated the corrosion due to dissimilar metals. And since both carbon steel and stainless steel are above aluminum in the series, the material loss is happening to the aluminum instead of the fastener, which I don't like. A zinc plated steel fastener would have been the best, because then the zinc becomes the anode instead of the aluminum.
Ohhh...you mean Phirrips head...Japan having their own Japanese Industrial Specification (JIS) interpretation of what we call Phillips head,
You know what they say...Ha, they were delivered yesterday also!!!!!!!
I’ll have to snap a picture when I get home tonight.You know what they say...
Those are sweet
Smart - If they are used for Jeering they will be all scratch up. Although if for a show vehicle they would look great.Those are sweet
