So the UCF bumpers holes do not line up with the original holes for the hooks. So now I can only attach it from the two bolts taken from the bottom because the bolts are too long with out the hooks. Nor have I had a factory sway bar for years. So I can’t use those bolts either
Where did you get this? Is it an actual kit you can buy or did you make it yourself? I’m interested in the sunrider tops but not for the priceStill 70 in Atlanta so installed the “flip ur top” kit. Should have done this earlier. Stock soft stop to sunrider in an hour and for $60
Flip Your Top WebsiteWhere did you get this? Is it an actual kit you can buy or did you make it yourself? I’m interested in the sunrider tops but not for the price![]()
It’s a kit that was posted on the “other” forum. It’s instructions + hing hardware to cut a small segment of the soft top rail so it folds back. Once you get past cutting (use a pipe cutter) your perfectly good top hardware it’s pretty easy. http://www.flipurtop.com/ I asked a bunch of questions and had delivered in under a week.Where did you get this? Is it an actual kit you can buy or did you make it yourself? I’m interested in the sunrider tops but not for the price![]()
If you kept up with show, Friday night we learned his name is grogu. I am hoping to get him in a vinyl sticker for the side of my hood with him pointing and have the saying "this is the way"WSS, please change you avatar to what it was on that other forum. My wife keeps checking out my posts here and now she wants a fluffy baby Yoda for Christmas too. I've already spent/wasted $1,000 on her and I'm waiting to show my surprise on my pair of white socks and some crap I never wanted. I now see clearly why I've been divorced 3 times. #4 after Christmas.![]()
Yes it is made to run with the anti rock. The high clearance aluminum.Which one is this? I have the frame width aluminum and it looks nothing like this, lines up perfectly. Is this one made with antirock in mind specifically or something?
What is preventing you from drilling that needed hole?So the UCF bumpers holes do not line up with the original holes for the hooks. So now I can only attach it from the two bolts taken from the bottom because the bolts are too long with out the hooks. Nor have I had a factory sway bar for years. So I can’t use those bolts either
McMaster typically has black oxide stainless steel for most of the common stuff.Finally finished installing the hood louver panel yesterday. Made a few mistakes, overtightened a couple of the fasteners, but overall it came out pretty nice. I think I'm going to look for new hardware though, I'd rather have black hardware than stainless. If anyone has any leads, let me know.
Also, Daystar hood bumpers, and I snapped one of the bolts off in the factory plastic footman's loop so I replaced it with a metal one.
Installed a B&M short shifter
