Door pin guides
I am looking for some door pin guides. I want to take the doors off more often without removing hardware. I currently have the rugged ridge replacement hinges and the hardware is a smaller thread. Anyone know if these will fit or have something compareable?
https://www.amazon.com/gp/product/B01K5SIPZI/?tag=wranglerorg-20
I have them. They are over priced like many TJ accessories, but they definitely do make putting the doors back on easier to line up. If you take your doors off frequently it's a good pickup.
*Misread your post. Don't mind me!
Sent from my iPhone using Tapatalk Pro
Reactions: Reign Mack
I have a set of these, they make it a little bit easier to put the doors back on again over priced for a set of pins but only slightly more expensive than a 14" pizza.
A simple way to make the doors easier to install is to cut the threaded portion off of one hinge pin. Partially insert the longer pin and the shorter pin will be easy to put into position.
Reactions: Ron505
You don't need to buy any hardware or remove hardware to be able to remove your doors Scott. The only thing you need to remove, which can be left off permanently, are the nuts at the bottom of each hinge pin. My doors haven't had their hinge pin nuts on in nearly 20 years. The doors lift right off.
Reactions: DC0046
Agreed. Here in Arizona I have my top and doors off on a regular basis. I just leave the nuts off the door pins. Easy on and off.
