Was hoping I might get some assistance on a wiring question I have.
I installed an OEM rocker switch for more control of the AC folllowing the steps in this thread.
https://wranglertjforum.com/threads/have-more-control-of-your-hvac.10111/
I went with an OEM one (fog light) as I wanted the switch to light up when I had the interior lights on plus an indicator for when the switch was switched on.
Here is the strange thing.
The switch functions as it is supposed to. Looking at the HVAC control, when I’m on any of the 1st 3 spots or the defrost slots, the ac won’t work unless I flip the switch. The problem is that the indicator light telling me it is on doesn’t light up.
However, if I switch the knob to the slots that would traditionally NOT have AC or turn it off all together with the rocker switch in the “on” position, the compressor will shut off (since they are non-AC spots) but the indicator light on the rocker switch lights up.
Any idea what would cause this?
Curious if I need to wire the switch up to a relay vs. how it says to do it in the thread above.
To summarize:
1. AC won’t turn on unless I flip the switch.
2. When the switch is flipped, the light telling me it is “on” doesn’t light up if I am in any of the AC slots.
3. When I am in the non-ac slots or off, with the switch in the “on” position, the indicator light will light up but the compressor shuts off.
My goal: when I am in the AC slots the indicator light on the switch lights up.
The wiring on the switch is your typical 4 wire MOPAR switch.
Black-Neutral
Blue-Accessory
Purple-Power
Orange-LIght source
To summarize:
Black-Neutral
Blue-Accessory
Purple-Power
Orange-LIght source
