I treated some tiny rusty spots on hinges and from trail rash. Essentially driving my OCD insane and now I’m fully aware of every battle wound the TJ currently has
How’d you treat them?I treated some tiny rusty spots on hinges and from trail rash. Essentially driving my OCD insane and now I’m fully aware of every battle wound the TJ currently has![]()
That double din with the back up camera is nicely done!PRoductive day.
1. Installed my modified OEM Foglight switch to have the ability to control my AC
2. REplaced the aftermarket rocker switch with an OEM fog light switch.
3. Finished installing the Double Din Car play stereo and aligned the backup camera.
4. Replaced the bulbs in the switches and ac control with LED's.
Next up: automatic door locks and reset of LED replacements.View attachment 191135
I used some rustoleum liquid and a soft brush. Some of the deeper areas I let it sit for a bit. Came back and it pretty much wiped right off. Someone else used the spray recently and it inspired meHow’d you treat them?
I saw that post. May need to pick some up myself.I used some rustoleum liquid and a soft brush. Some of the deeper areas I let it sit for a bit. Came back and it pretty much wiped right off. Someone else used the spray recently and it inspired me![]()
I got a quart size bottle a few months ago, stuff really does work wonders!I saw that post. May need to pick some up myself.
Can I ask what LEDs you used for the climate controls and switches? I didn't even know the switches lit up until I bought some to replace the broken ones that came with my TJ.PRoductive day.
Awesome, thank you!From superbrightleds.com, the NEO3-xHP work for the little indicator light that comes on when you activate the switch.
NEO4-xHP to light up the print on the switch As well as the heater controls.
NEO4-xHP - 3 for the heater controls and one for each switch.
NEO3-xHP - 1 for each switch.
x = used for the color you want.
There is a write up on LED’s as well. It made it all really simply with the links! It was actually what got me to this forum!Awesome, thank you!
There may be others, that just happens to be the ones I’ve used.Awesome, thank you!
I'll search for it, I'm pretty sure I've run across it in the Resources sub-forum before. Thanks!There is a write up on LED’s as well. It made it all really simply with the links! It was actually what got me to this forum!
I order stuff and it take 3-4 weeks...Amazon or ebay. I cant even get some things out of the States anymore but I could pre-covidMust be nice, Amazon used to have 2 day prime, now it is 10 day prime.
DON'T spill that coffeeI'm actually totally enjoying the riinocon at the moment with the top off and the hard doors on , windows up ,spider web on
I'm at the McDonald's drive-thru getting a hot coffee and a couple of burgers and a small Coke
To be true to the thread I tucked in the corners of my soft top and got them secured to the header correctly , and change the oil and did something so stupid I'm not even going to put it on here.... Let's just say I've got to use a lot of oil dry... If anybody gets on here and says I act stupid that's not true... It's not an act.
Anyway I'm having a lot more fun than mess to clean upso all is good
I hope not enough oil dry to soak up 6 quarts of 10W30.... Let's just say I've got to use a lot of oil dry...
Put the plug back in next timeI'm actually totally enjoying the riinocon at the moment with the top off and the hard doors on , windows up ,spider web on
