Trying to find vacuum line part
SBarber1
Navarre, FL, United States
What is the piece that goes into the cabin called? I cant find it any were?
Fill out your profile so we know what year, engine & transmission you have. I doubt that is still available. I think it’s part of the vacuum harness. Remove your glovebox and follow the vacuum tube. You can buy bulk nylon vacuum tubing at any Napa store.
That type of vacuum line is readily available at most auto parts stores on the Help rack sold in small coils. You can attach to the old and pull a new one thru.
Get yourself a piece of rubber vacuum line that fits over the plastic vacuum line to reconnect each end. I had the same line break on my 03. This repair fixed the problem.
Filled out profile. Yea pland on pulling box out tomorrow. What about the boot? Just replace with shrink tube? It was pretty dry snd loose. Thanks
Try to pull & twist it off, otherwise just use flexible vacuum hose like @Rich1961 suggested.
I believe it’s call out number 4.
Or it could be call out number 10.
Found a picture. It’s part of the vacuum harness that plugs into the vacuum switch. Easier to just repair.
