Tried to get those bumper bolts but couldn't, so ill be grinding the heads off tomorrow and doing them that way.
Spray them twice a day for about a week w/ liquid wrench...most will come out, if not, put a torch on them...they'll come out.
EDIT: get a cheap torch at WM in the plumbing section.
front brake pads and started to measure in the garage for the harken hoister i got. only neighbor i have willing to help take off the top is moving to indiana!! wife and kid are no help, so its time for some simple machine mechanical advantage. wife is happy because its forcing me to clean out the garage and she can pull her car in now (she thinks!!!!!)
Im always curious about the top being a problem. How much do they weigh? Why not overhead press it off?
its not so much the weight, its awkwardly unbalanced and setting it down without breaking anything would be tricky too. I had been looking for a hoist for awhile just so I didn't have to bother the neighbor every time i wanted the top on or off, his pending move just sped up my timeline
Reactions: Blondie70
makes sense.
Yup, Kroll worked like a charm on all the top bolts. Unbelievably easy to get out.
Bottom two are stripped by the PO, sooo... trying to figure that out lol. They've been kroiled as well, but I've had no luck trying other extraction methods so far.
Are they the torx, or standard bolts?
If standard, beat a smaller socket on w/ a hammer
Torx. I've tried punching in different sized torx, a flathead attachment, left hand drill etc. Tomorrow ill have an angle grinder so ill try to cut down two sides and use a wrench, if that doesn't work im going to just cut the bolt heads off and use a vice grip for the rest of the bolt .
I've had luck removing damaged bolts and nuts over the years using this style of tool. I happen to have a Craftsman set, but I've seen Irwin makes some that are sold at my local Lowes and ACE hardware stores.
Just kick it a few times. That always seems to work in the cartoons.
I may check that out. I saw one like that at home depot this morning but it didn't look like it'd fit over a t55. I might check lowes or the local hardware store and see.
Its worth a shot, though!!
Finally downloaded Gaia and found a couple trails this afternoon in NH. One was definitely too dicey for me to attempt on my own with no recovery gear but its definitely doable, the other was a slightly bumpy but very drivable dirt road so I had some fun.
I'll be going back out tomorrow with a friend, and hopefully with the winch on tomorrow assuming I can get the damn bumper off so I may try some more intense stuff haha !
Grinding the heads off doesn't really solve your problem because (unless you have some very special grinding tools), you can only grind it flush (literally removing only the head)...you still have the rest of the bolt going through the hole in the bumper, keeping you from moving it any way except out (away from the frame, in the same direction as the bolt is threaded). EDIT: I would be surprised if you could "roll" the bumper off of the frame, rotating around the lower bolts-less-heads...but I could be wrong.
I would try heat if you have a torch; even a propane torch will add some hot to it, and the chisel method. Here's a vid of the chisel method. EDIT: I meant to mention that I have had surprising success with this method, even on bolts that I, myself, had stripped out because they were rusted in.
You can also try a pipe wrench it you have one. And don't forget that simply whanging on it a few times on the head with a hammer can actually help "shock" it loose.
Be sure to get a chisel intended for use on steel...the are called "cold chisels" like these https://www.lowes.com/pd/IRWIN-3-Pa...UjsOEkkvvajnxfjiftBoCjNoQAvD_BwE&gclsrc=aw.ds
Yeah, I wasn't thinking, that bolt head is pretty big. I just went out and checked and the biggest size I have is for a 3/4 inch or 19 mm, and it wouldn't fit over it. If you find some with larger sizes they might work.
