Suspension not adding up
I have the Currie bump stops. They extend the top and bottom. Need to drill and tap into the bottom. They also prevent the spring from un seating at full droop.
you have a 4" lift? any body lift? did you cycle suspension and like where currie limits?
Saavy has one of the best 1 1/4 inch lifts. Not too expensive either. Some other body lifts can do damage to the tub.
any experience with the currie one? I read about it and it needs the original bushings which I'm not sure I have so I'd need to replace those as well.
