Jelly!Christmas in May!
My Rubicrawler from just arrived. This was an unplanned purchase .. and I haven't been this excited for Jeep part in a while.
@RubiconSpyder you are the man ! Thank you !!
Guaranteed rust free! Lightweight too.
Love your wall decorations!
Just be careful of sun damage - it can rot PVC!Guaranteed rust free! Lightweight too.
Somebody is ready to win the slowest race at Moab next year.
Are there more??
Good job replacing that lot!
Went to my local muffler shop with a piece of 2.5 in exhaust pipe for a custom tail piece. $5 later and I have something to weld up. Made sure to give it a 20 deg baloney cut on the end. Hopefully I have it in the least susceptible area for damage.Oops. Wasn't done. Nice low note with the MBRP setup.View attachment 164334View attachment 164335
I didn't put the tip on because it ends up in the crush zone behind the tire. I'll go to my local muffler shop and have a piece bent to exit straight out the back.
Oh and lrt me give a shout out to Mach 1 Muffler. If you're in the Spokane, WA area this is the shop you want.Went to my local muffler shop with a piece of 2.5 in exhaust pipe for a custom tail piece. $5 later and I have something to weld up. Made sure to give it a 20 deg baloney cut on the end. Hopefully I have it in the least susceptible area for damage.View attachment 164829View attachment 164830
Ugh!And the other thing is, they weren't tight. Or tight enough. A 5 year old having had a wrench in their hand for the first time in their life could have loosened them.
Edit: ordered fender flares today.
Your pup seems to have grown a rather bad case of LJ on his nose...you should probably have that removed.Finally had some half decent weather, albeit muggy as hell, so I took advantage of it and threw the soft top on. During the process I remembered how bad of shape my zippers are in, what a PITA. A new top is in my future lol
View attachment 164769View attachment 164770
Did you have to cut the sway bar cover to mount that winch? I want to get a winch, but I also want to keep that cover without permanently disfiguring it.
Yes, you have to cut the cover. Why do you care about cutting it? Do you plan on removing the winch at some point? You could always just remove the cover and run without it.
I, personally, like the stock-ish look of the Jeep, hhnce why I have no plans to lift the Jeep. Similarly, I like the way the cover looks right now.
Just been on and off on deciding to get a winch, seeing if there's any way to add one without cutting that cover.
Thanks, though!
Yes, lots more. I'm up to 15 or 16 grilles....CJ, YJ, TJ, JK...I also have various other stuff including a CJ and two Willys tailgates, side panels, etc.
Probably less than $40 on marketplace. Some one was giving one away a while ago.If you throw a winch on the front you're not going to be able to see that cover anyway. The only reason I put it back on is so I didn't have to look at the rusty swaybar mounts. I think you're over thinking it but I also don't really care how mine looks so I'm the wrong person to have that conversation with. I cut the cover with my pocket knife and no measurements.
You can purchase a cover on ebay for $40 so just budget a used cover to cut into your winch cost.
