GSO06UNL
I haven't taken mine apart yet, but it appears I have corrosion on the housing surface as I look through the lens. If anyone's had the same issue, suggestions on what to clean the metal surface with...brasso?
Photos?I just did this with mine. Had some self leveling windshield sealant around that I used for reassembly. Installed yellow Hella fog light bulbs. Have to say they look great!
It works on real chrome like bumpers, I've used that trick. The problem is if you rub at all on those reflectors all the plating goes away in about 2 seconds and you are left with nothing. It isn't corrosion, the chrome is missing, that's what the brown spots are.Sounds crazy but I just cleaned up a very rusty chrome fender by folding up a piece of aluminum foil, dipping it in water and scrubbing very hard on the chrome. You will be amazed. I was skeptical that tin foil could polish rusty chrome - but it works! It won't get rid of all the pitting but restores the shine.
Noted, thank you for clarifying that before anyone ruins a reflector even more. I've never done it for a reflector, but like you, I have for bumpers and it worked.It works on real chrome like bumpers, I've used that trick. The problem is if you rub at all on those reflectors all the plating goes away in about 2 seconds and you are left with nothing. It isn't corrosion, the chrome is missing, that's what the brown spots are.
They are just Hella 500s in the "special" Jeep housing. A pair of Hellas are about $70. All you need from the kit is the lenses and bulbs. Plug right into the factory wiring.View attachment 44428 Both of mine look like this. Anybody know where I can get replacement lenses?
Your avatar pic is awesome!I just did this with mine. Had some self leveling windshield sealant around that I used for reassembly. Installed yellow Hella fog light bulbs. Have to say they look great!
I am buying the Hella 500,s but need to know if the fitting brackets will work.So if I read this correctly, I can buy hella500 light and install them into the oem fog light casing?
