Capt'n
First attempt at plastic bondo for fender flare repair. Painting up next
Is your front windshield tinted? I have mine at 50%Bought some new rubber shoes this week and got her cleaned up. Obviously I had to do a quick photo shoot...
View attachment 155815View attachment 155816
Sure,Hey I have a few questions to ask you if you don’t mind!!!
Right, my Jeep is not my daily either so I went pretty dark.Yes, I had the doors and full windshield done to match the top. I don’t remember exactly but I believe it’s around 10%. If this was my daily driver I wouldn’t have put tint on the full windshield, just a brow.
Is that a loose bolt on your timing cover?Got started on replacing the water pump, hoses, metal water pump inlet tube and tstat + housing finally today. Passenger side lower fan shroud bolt was a real pain to reach but otherwise pretty straightforward. The biggest problem I've run into was all the caked up oil and gunk congealed along the edges of the mating surface (see bottom two photos). I don't think I can put the new one on until I clean the gasket as well as all the accumulated crap around the edges. Suggestions welcome. I probably just need to sack up and clean it.
Also, getting the gasket off is as bad or even worse than I was told to expect ha. Keeping it away from the openings was tough, even with towels stuffed in there. Tomorrow I plan to finish cleaning the surface and then I'll put it all back together.
View attachment 155852View attachment 155853View attachment 155854
Last pic at the bottom.
You can also get some metal screen material and melt in into the plastic at the split to strengthen it and keep it from tearing again.First attempt at plastic bondo for fender flare repair. Painting up next View attachment 155827View attachment 155828
Here is a bumper I repaired years ago using this method.You can also get some metal screen material and melt in into the plastic at the split to strengthen it and keep it from tearing again.
Don't let @KimsJeep hear about you painting over purple with black!Picked up purple (future black paint job) half doors and soft top hardware.
