Ok, I won't worry about the cam bearings too much then. I will see if I can check for end play while I'm checking the crank shaft. Thanks again for the thoughts on the oil! I'm going to definitely replace the chain, got the new one in today, and I'm going to replace that bearing I posted a picture of. Something nasty got in there and I definitely don't want to put it back on the crank.Pulling the cam and visual inspection is the only way I can think of. They aren't as delicate as the other bearings btw. I was worried when I nicked mine but was told by several engine builders not to worry. Cam walk (end play) and crank walk should be concerns and checked for sure. Should be able to do that with a pry bar from underneath.
I wouldn't run diesel oil either. That Rotella thing has been Internet lore forever since before they started decreasing zddp in those oils as well. Plus different detergent packages. Run something formulated for a gas engine. Like I said, I recommend Valvoline VR1 but there are other good options out there.
That timing chain is freaking toast! That last bearing you posted doesn't look good either. I wouldn't reinstall that personally. And if one bearing looks like that, I'd plan to check them all. Do your have a local machine shop you can show them to?
I'm seriously about to that point, lol. I'm going to replace that one main bearing and check the thrust bearing, but then I think I'm done underneath there. Everything is super tight and all my tests are turning out good so I don't think there is much reason to dig too much more into it. If nothing new shows up while I'm checking/replacing these last few things then I think I will just replace the chain and move on to the next possibility which is lifters or flex plate.Button it up and replace the chain, I would not go further into it personally. That chain was really bad, fix it and then decide what to do next after testing it out.
Any opinions on bearing metal type? I ordered bearings and they are the tri-metal kind. After they came in I realized that there are aluminum (bimetal) too. I've seen multiple opinions on both, do you guys have opinions on what is best to use in our 4.0 engines?
