I haven’t made any mistakes yet, but I haven’t done anything to my Jeep yet either. Let’s hear your biggest mistakes when modding your Jeep so nobody else makes the same mistake.
Interesting. Figured the sidewalls on the KO2 would be stronger than the Duratracs. They might be, but haven't heard many complaints on the KO2 sidewalls.KO2 tires. I thought they were fantastic, which they were, until I started running them more on the rocks. I had two sidewall punctures and chunks missing out of the tires every-time I went wheeling.
Installed a smittybilt bumper and tire carrier
I had/have the XRC carrier and bumper. My complaints are mostly directed toward the carrier. After awhile it began to shake/rattle like crazy, it also sagged an inch if not more. I had to pick it up in order for it to fit into the latch housing. The latch also allows water to enter and will rust. I had to beat mine open with a mallet if I wanted in the back (not kidding either). The carrier is mounted to a post that is mounted on the bumper. The carrier just sleeves over the post. A good carrier would have a bearing there. I will say though, that the bumper did include frame tie-ins, which many manufactures do not include (you have to buy separately). And the finish on the bumper has held up well despite all the gouges and dents mine has. Where I wheel though, the bumper is far to large and takes away from my departure angle. It gets hung up on the corners, as well as the low mounted hitch.Curious why? I just installed a set of XRC bumpers on my TJ I got brand new for $300 for both. They seem pretty good so far. A friend has them on his JK and has hit the Rubicon a dozen times with no issues. Just curious what I may run into, thanks!
