Any chance that you could do a cover like that for the windshield vent. I’ve got a couple of broken pieces in the grid. They’re way too fragile. Just something that would screw over top or even slide into the recess if you broke them all out. Just a thought.
So where ya heading fellow Washingtonian?Today was prep day for next weekend,
Aired up the tires since I can’t tow next weekend. I got rear ended last week in the truck
Re-spooled the winch
Checked bolts, unjoints, fluids.
Put on soft top
Packed tool bags
Strapped everything down
Should be about ready to roll come Friday night
Going to need some pictures!My TJ rig is a weekend camper with solar power back up for my ARB fridge. Otherwise she sits weeks on end with no battery tender. So I mounted 30watt / 2amp solar panel from ebay for $20. So when she sits the battery stays charged.
Just posted some photos.Going to need some pictures!
That looks fun! Nice job! I would also do that if I had a rack on top.Just posted some photos.
I like it, thank you for the idea!! I will be using that for mineI had the same issue, so I bought a section of metal gutter cover, cut out a piece and hot glued it to the under/back side. Not only were the fragile vent sections broken but the thin solid part in the middle of the vent area was also broke.
I think it looks good and seems to work very well.
View attachment 123264View attachment 123265View attachment 123266
I was a bit surprised after reading different threads about tj dome lights. But when I removed my doors last spring I was ready with one of those switches you find online. That's when I realized my lights time out. Don't know if it's a year thing or maybe a Canadian tj thing as my tj was produced for their market.
I will have to test my 04 and see if it goes out, I have been pulling the fuse.This is how my '05 is too. My '97 would stay on forever. Well, until it killed the battery.![]()
I bought that switch with the intention of putting it in before I found out my lights timed out. So if anyone needs one, selling cheap.2000 TJ here put the top on today, I have a switch in the glove box wired to the fuse.
View attachment 123267View attachment 123268View attachment 123269View attachment 123270
Which sport cage kit and floor tie in did you go with?2000 TJ here put the top on today, I have a switch in the glove box wired to the fuse.
