Has anyone replaced fender flare nutserts with stainless steel ones?
RangerZ21i
Southeast LA
Has anybody replaced the rivnuts/nutserts that are used to attach the fender flares with stainless steel ones?
Can you put them in the fender to replace the bolts and nuts that require removal of the fender liner ?
I've never replaced them, but it would be easy to do with a rivnut / nutsert tool.
That's what I was thinking.
And while I am doing it also replace all the attachment points that require the plastic liner to be removed to get the flares on and off.
I had to replace my drivers side fender. The new fender did not have the Riv-Nuts installed. I bought a kit with new hardware including Riv-Nuts, plastic nuts, bolts, washers and screws. The Riv-Nuts and bolts are supposed to be stainless, but they are not high quality, I tested them with a magnet. Overall happy with the kit. One problem is that the washers they give you are too small so I went to Ace Hdwr and bought some fender washers and painted black. I bought a Riv-Nut tool on E-bay for about $10. I think I recall @mrblaine posting a thread on how to make one. All in all the flares are back on.
I replaced ALL of my fender flare attachment hardware with Nutserts, though not stainless steel. I did use Never Seize on the screws - I can take my flares on and off in mere minutes...
It seems that a lot of you "bag on" Nutserts - I've been using them since the '90's - prolly installed a thousand of them on ~20 different vehicles. I've attached door panels to fiberglass doors on 5 vintage Corvettes and on every one of the four Jeep Wranglers I've owned - probably had "issues" with less than a dozen of them. Worst case, remove the bad nutsert and install a larger one - I LOVE 'em! I used 'em to hold my side steps on too; here's a pic of the fender flare Nutserts:
No, but a good idea. Anti-seize too and 25% less torque. All smarts
This is exactly what I was thinking. Thanks for posting the pic.
Reactions: TheGanzman
Negative. Saying that there is less nickel and/ or chromium in the stainless they used.
If you add the nickel and chromium in then the stainless would be to hard to properly flare and squish the rivnut. When I was a kid stainless was hard. Real hard. Never rusted, but you couldn't bend and form it like the "stainless" today. No mufflers and pipes. Basically table tops and such for the food industry. Could barely get a drill bit though the stuff. These new versions allow it to be workable. Always a tradeoff.
Reactions: Blondie70
Do you remember the nutsert size?
TIA
I think you have a great idea for your environment. Here in the rust belt they fail quickly. They rust and seize then spin freely and become a PITA...thus the disdain for them.
If you put a bit of red thread lock on the squish and lock area of the rivnut when installing then you get a good chemical and physical bond. And all stainless needs antiseize to prevent galling.
I did this as well (probably sub consciously remembered this post) , what screws length/type did you use? I used 20mm long SS button head screws because that's what I had on hand and it was a mistake. I think shorter hex head screws would have been better.
That was SO long ago that I can't possibly remember; sorry! I know that they were stainless steel, and that I applied a liberal amount of anti-seize; beyond that, I can't be of much help...
They are M5x8. The screws that came with my bushwacker flares were very long at 35mm. They threaded into the 2 rivnuts that survived... The rest I had to replace with M5 rivnuts and I went stainless.
Here in the rustbelt rivnuts seize. Here are the ones I had to cut off.
Here in the rustbelt rivnuts seize. Here are the ones I had to cut off. View attachment 148931
I just started prepping for my Bushwacker install and already have 2 rivnuts spinning. Where did you get the M5X8 rivnuts?
