Best tow bar set up for an RV tow
How does the base plate attach? I will still be in this shitty situation with the torx?
Drivers side bolts to bottom bumper bolt and steering box mount. Passenger side bolts to bottom bumper bolt and through frame with anti-crush spacers. You have to drill through frame for one bolt on pass side.
Sounds like it’s bit easy at all to install then
How would we set the sale up?
PM me your address and I'll get a quote to ship UPS or Fed Ex. Do you have Paypal?
Here is a PDF of the instructions for the base plate. It's a pretty easy install. You have to drill one hole in the frame on the passenger side. The driver side bolts up using the existing steering gear bolts.
Now that I think about it, you still need to remove that bottom bumper bolt because the base plate mount needs to bolt there.
I’m still interested in the base plate. Somehow I got another bolt off the bottom on the passenger side but, the bottom one on the driver side has to be cut off. Let me know what works and I will buy it
Ok, I'll package it up and get a quote to ship.
I don’t see the pm area in here to give you full info.
It be shipped to Mahomet, il
61853. It have to go ups or fedex. USPS is outrageous over 2-3lbs. I’ve learned that over the holidays. Thanks and I appreciate the offer and help.
