Chris
Administrator
Staff Member
Gillette, WY
Just thought this would be a handy thread to have as reference. The light bulb types / sizes for the 1997-2006 Jeep Wrangler TJ are as follows:
1997-2006 Jeep Wrangler TJ Replacement Lightbulb Size Guide
Low Beam Headlamp Light Bulb Size: H6024
High Beam Headlamp Light Bulb Size: H6024
Parking Light Bulb Size: 3157
Front Turn Signal Light Bulb Size: 3157
Rear Turn Signal Light Bulb Size: 1157
Tail Light Bulb Size: 1157
Stop Light Bulb Size: 1157
High Mount Stop Light Bulb Size: 921
Fog/Driving Light Bulb Size: H3
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 168
Dome Light Bulb Size: 211-2
Step/Courtesy Light Bulb Size: 906
Under Hood Light Bulb Size: 561
Instrument-General Light Bulb Size: PC74
Automatic Transmission Indicator Light Bulb Size: 658
Has someone done this for leds?
It's the same thing, just buy whatever bulb you need in an LED from the above list. So if you need a front turn signal bulb, you'd just search for 3157 LED bulb.
Simple as that, literally.
When you go to LED’s, don’t you have to add a resistor in-line? If so, what resistors we would need for above bulbs?
For the 01-06 use a novita 470 flasher. It has been proven on two different occasions that it works to correct hazards failure and hyper flashing. Most of the heavy duty led flashers don't work with the hazard lights.
Can be found on Amazon or at local auto part stores.
Novita Lighting Control Module (LM470) https://www.amazon.com/dp/B0025QL4OS/?tag=wranglerorg-20
Thanks Chris, this is really helpful. What about the interior bulb that's built into the hardtop? Some may call it the cargo area bulb?
Mine does...is this not a factory hardtop? I have a '99 Sahara:
Reactions: FishinSam
The 1997 TJ is a bit different:
Step/Courtesy Light Bulb Size: 89
Sound Bar / Dome: 906
HVAC and Instrument: 74
