TJ's TJ
Total cost $435 including new O2 sensors:
Thanks, may seem like a waste of time to some, but remember 1/2 the point of this project is to teach a 14 year old...
Fully understand. My 20yo and I work quite a bit together. He's got a great work ethic.
He's building a K30 off road truck. In fabrication he's years ahead of where I was at his age. (It doesn't hurt that I have way more tools around that weren't available to me in my youth.)
BTW: Its going to be too nice to put on the salt....going to have to get a HOOPTY car for the winter!
And the tire and wheel fairy came:
285/75R16 (~33”x11.7”) Nitto Trail Grapplers on Vision Manx 16x8" wheels with 4.5" BS. I know they are Load Range E, but we wanted 4.5" backspacing in an 11.5" tire and this seemed to be the only way to get there. By my math and research, these should just clear the front control arms and should only stick out around 3/4" past the rubicon flares... We haven't put them on yet, will report back once we do.
Caster Check:
Pinion shows 83 degrees:
With the arms set to the Currie recommended control arm lengths for a 4" lift:
According to this table, the 83 degree pinion angle on a Dana 35 low pinion should translate to ~5 degrees of caster:
This seems to be reasonable middle ground. More pinion angle would put the front driveshaft into better alignment, but would decrease caster angle. I guess we will just have to see how it drives...
I've really enjoyed this thread. Absolutely awesome workmanship. I'm sure your son must be so appreciative for this! He's learning such an awesome set of skill at a young age!
Thanks. Yes, he is very proud of his project. Maybe that is the best lesson that will come out of it. The "Built, not Bought" mentality.
Caster Check:
Pinion angle trumps Caster. Get the pinion angle correct, then dial caster in until it vibs...then back it back off until the vibs go away.
I went poking around the shop and found a bunch of 4" wide x 1/4" Stainless Steel strips about 6' long. Guys in the shop said it had been there for years and it was ok to use some. Perfect for a rear bumper. We have been looking for a while and can't find something in a reasonable price range. Lots of nice ones for $500+, but we can't justify spending that much on a bumper. So off we go to build one that matches our $200 EAG Front bumper:
75953
75954
75955
Wow that's a lot of weld:
75956
And a lot of grinding:
75957
Fits perfect:
75958
75959
Very heavy and strong.
We ordered a set of these to add to it next:
75960
So with shipping we will have all of $37 into this bumper...
I still love this build thread!
If you have ever tried to drill stainless steel, then you know that it can be hit or miss, very often endind up in an overheated drill bit that will harden the local area, making it impossible to continue with drilling as an option. We are adding provisions for a bolt on hitch receiver. A quick template was made for the plasma cutter. It made quick work of adding 3/4" clearance holes in the bottom.
77082
5/8" stainless Steel nuts on the inside:
77083
77084
and a $22 step bumper receiver hitch (very well built I will add), makes for a easily removable hitch for the occasional tow. His request was to be able to tow our very light 3 rail dirt bike trailer:
77085
Also, the clevises came from AtoZ fabrication, very nice pieces, well worth the $27. They were a bit tall, so we machined off about 5/8" of material prior to welding them on:
77086
77087
Awesome thread. Your boy is going to have a great work ethic compared to most.
We need work ethic like crazy. It’s almost vanished. It’s so important for fathers to invest in their sons and daughters to instill in them this work ethic and know how mentality! Kudos
We don't plan on putting lights all over our jeep, so we cut the light tabs cut off the front bumper:
78280
78281
Then got both the front and rear 100% coated in POR-15:
78282
78283
They will get top-coated with black raptor liner this spring with the flares and the hard top
Reactions: bedhed and JMT
