I made an inner-fender liner out of 1/8" neoprene sheet and am holding it place with some push in clips.
When you get the front done and it is steering and driving, we'll chat and I'll explain a lot of stuff that will help get it tolerable. My learning style can best be described at persistent brute force trial and error. As such, I keep at it until I figure it out or give up. The rig will have some steering issues. I've explained what I've done to a very smart guy and he has explained back to me that although most of my terminology is only accurate if you understand the issue, my solutions are dead on and work as predicted.
The problem will be darty steering due to the inability to achieve Ackermann. We are going to mitigate the problem by adding some toe out and increasing the caster. The trade-off will be a slower response off of center, but it will be very tolerable and certainly more desirable than the darty way it was.
toximus;39688202 said:To finish off the transfer case I installed a sight glass made from these parts (inspiration came from NuckelHead):
- 2x -6 AN to 22mm x 1.5 Metric Adapter (FRA-460414-BL)
- 2x -6 AN Socketless Hose End (FBL1532)
- 3/8" Clear Fuel Line
I have some concerns about it snagging branches on the trail so I'll be carrying the factory plugs and enough fluid to fill it back up until I'm sure it'll be fine.
Probably.Unrelated to the recent work, but seeing the Savvy cross member reminded me of this. Didn't you weld the cross member mounting tabs directly to the frame?
That will get you close for mock up but the pinion will be too high for final. The reason it is too high is the DC joint actually drops down where the tube attaches since the DC joint splits the angle. You're setting it for a single joint at each end shaft, but it will get you close.This morning I revisited a mod I did in 2017.
At the time I wrapped the straight thread plugs with teflon tape. They've been slowly sweating fluid ever since:
I cleaned the area and am trying to solve the leak with crush washers. If this doesn't solve it, the stock plugs are going back in.
I can't remember if I showed this before, but here is how I've been sitting pinion angles: Place the yoke on the TC and axle at the same angle, thread string between the 2 yoke, and use a square to check the angle.
Probably.
It makes it easier to install the raised weld on Genright brackets for the body mounts.
And that's exactly what you did!Post 168: https://wranglertjforum.com/threads...treetable-adventure-lj-story.9956/post-210070
The Savvy C brackets don't fit with the raised body mounts.
And that's exactly what you did!![]()
Have you been able to figure out the frame and belly heights yet?Every possible gain I can get I've been trying at.
Take a look at my frame building posts to see where I used tubing to replace the nutserts.
