Anyone sell rocker guard covers?
Nicholas
Tampa, FL, United States
I’m looking for something that can cover up the outline of the original side flares behind the fronts, as well as cool get the holes
No, sorry I don’t even think I’m saying the right word it’s where to cover up this thingy majiggy behind the front flares
No, sorry I don’t even think I’m saying the right word it’s where to cover up this thingy majiggy behind the front flaresView attachment 64584
Ohhh, you need some rocker panels to cover that up. Either some sliders or just rocker guards like you find on they Rubicon models.
Reactions: Nicholas
On my last Jeep I rolled on a 4" strip along the bottom from front to back in black bedliner. I then used black rubber plugs in the holes. It looked really good and would look great on a red TJ.
Reactions: Nicholas
That’s pretty unique actually, thanks for the idea
For the small holes you could use JB Weld to fill them before you roll on the Berliner. Then you would only need a plug for the large hole.
I run some aluminum diamond plate panels from PBR Products on EBay. Mostly for looks and to cover all those holes. That or run a full slider.
A company makes a flare delete kit that mounts flat to the tub and only takes up that space that the flare used to occupy behind the front fender flare.
For the life of me, I have been unable to come up with the right combination of words to get google results.
Reactions: Shane Mckinley
I thought your requirement was pretty straight forward...You are looking for something like this:
Give Bushwhacker a call. I will admit, I have yet to see a set in a long time. But I know for a fact that they made them for the TJ side flare.
I've purchased (2) sets of these over the years, from this guy at the link below:
http://jocartsparts.com/products.php?cat=JEEP&sub=TJ
*Once at web-link, scroll-down to see the panels for TJ's.
These are heavy gauge aluminum, and come with a very heavy coat (2 coats) of RhinoLiner.
I bought the first set maybe 5 years ago, when I still had the front flare extensions (he makes a set with the curvy cut-out's for the extensions). I bought the second set after permanently removing the flare extensions.
He also sells a nice set of fender-top covers, which include a 90-degree bend over the top edge of the fender (I also have these installed).
I later had a fab shop make a custom set of matching panels for the quarter panel area directly aft of the wheel wells (see photo, below). My rocker sliders are frame-mounted (made by Body Amour):
P.S. Yes, I know my hard top and fender flares are badly faded. I'll get that taken care of, soon :confused:
