#1 make sure the heat shield above the catalytic converter is still in place and #2 keep the carpeting in place Missing either of those will produce a floor hot enough in warm conditions to make life miserable.... any suggestions on dealing with floor heat?
Marketing. The factory cat is larger than most of the aftermarket cats and has the same size honeycomb matrix. The factory exhaust is not restrictive.Do you have any experience with "after market" catalytic converts that are "more free flowing"? I wonder if these produce less heat? I will check the home depot and see what I can find, thanks!!!!
Save money and go to a local shop and get something close to stock.gotcha, thanks.... my muffler is starting to "decompose" at the seams, I was thinking of doing the Banks car back in stainless steel, thoughts?
What is your closest city there in Virginia? I wouldn't buy a cat-back out of a catalog either, I'd rather drive to the closest muffler shop, even if it's not close, and tell them what I wanted instead of hoping I liked what UPS delivers. Not to mention you'll save $$$ and help keep your local muffler shops open and employing your friends and neighbors.There in lies the issue, there are no "local" muffler shops, all there is is Meineke and Midas, neither of which I want anything to do with.....
Just put a Banks on mine and it sounds nice and everything went together great. No issues at all.gotcha, thanks.... my muffler is starting to "decompose" at the seams, I was thinking of doing the Banks car back in stainless steel, thoughts?
more than an hour and a half to the nearest "local" muffler shop..... I hear you, and admire your ethos but, for me, it is difficult to justify, it would take more time than I have, three hours travel there and back plus an hour or two for them to do the work, that is an entire day, I do n't get many days off.......What is your closest city there in Virginia? I wouldn't buy a cat-back out of a catalog either, I'd rather drive to the closest muffler shop, even if it's not close, and tell them what I wanted instead of hoping I liked what UPS delivers. Not to mention you'll save $$$ and help keep your local muffler shops open and employing your friends and neighbors.
You're right there aren't many but Mr. Muffler is only 45 minutes/25 miles away from you in Waldorf MD. I'd drive 25 miles to avoid having to get a muffler system delivered by UPS.Alexandria, VA
I installed a pair of Gen Right long narrow vents to help with heat soak. Of course a week later I read about the factory fix. But as others have found, it keeps the engine compartment temp down. And you can touch the hood even when the engine is hot AND the Arizona sun is HOT!
