P0301, P0302, P0303, P0304, P0305, P0306 (the dreaded misfire) and how I solved it
CodaMan
California Escapee
Dover, Arkansas
At some point all 2000+ TJ 4.0 owners will have a misfire CEL. They can be very difficult to troubleshoot and expensive to just throw parts at.
Mine was a cylinder #1 misfire, but this would work with any single cylinder misfire. Random misfires (P0300) would be troubleshot differently. I hope this helps others.
Note: A P0303 may be caused by a Heat Soak issued which Jeep put out TSB 18-031-03 on it. Basically all you need to do is wrap a piece of insulation around the #3 injector and zip tie it on. The Jeep TSB calls for this product to fix the problem: https://www.amazon.com/gp/product/B007O3QHDK/?tag=wranglerorg-20
I've been having a p0301 misfire for almost two tears. Never random or any other cylinder. But since my California registration is due and this is my year to pass smog, I figured that I better work on it ... I had until October, 20 to get everything good. Here's how I troubleshot and solved the issue:
1) Since this is a waste spark system (2 cylinders fire at the same time) and only cylinder #1 ever failed, I ruled out the Coil pack. I guess it could have been the #1 boot, but it looked good.
2) I pulled the spark plugs from #1 & 2 (#1 looked good), checked the gap and swapped them.
Drove the Jeep and after about 150 miles the code popped again. It had a pending misfire at about 50 miles, but at around 150 it went hard. Checked the monitors and Catalyst and Evap were not ready. Note: In California, the Evap monitor does not need to be ready to pass the smog test.
3) Swapped injectors #1 and #2.
Drove Jeep with same result as above.
4) Used a NOID Light to check injector signal to rule out the computer and injector wiring. All good.
5) Performed a dry compression tests on all cylinders, #1 was 125, about 10 below the next lowest, #3 ... A wet test yielded about the same results. Not enough for me to call it a ring problem.
6) Performed a leak down test to all cylinders, #1 leaked just a hair faster than the others, again not enough to call it bad.
7) Replaced both valve springs for cylinder #1.
8) Replaced the intake/exhaust manifold gasket, maybe it had a leak I wasn't detecting. Note: these are MUCH MUCH easier to change if you spend 30 minutes and remove the front fender.
Drove Jeep with same results as above.
Analyzed past troubleshooting and determined that the problem must be in the head ... valve or head gasket.
Removed the cylinder head and noticed a small burn on the cylinder #1 exhaust valve. My guess would be that once the valve rotates onto that area it reports a pending misfire code and once it rotates there again it pops a hard code.
Since I had the 0331 cylinder head that was prone to cracking, I decided to replace it with a re-manufactured TUPY head. Total job completed by myself —- about 6 hours.
Drove Jeep for 10 miles and had ALL monitors (except Evap) went ready. Immediately went to the smog shop where it passed with flying colors. Yeah!!!
Since the successful smog test I have driven about 2000 miles with ZERO problems. In fact the engine runs much smoother now.
Relief!!!
Fantastic write-up, one that should be very helpful as well. Seems like every week someone is posting with a p0301 error code!
Reactions: CodaMan
Best advice ever. Replacing the intake / exhaust manifold gasket is royal pain in the butt unless you remove the fender (ask me how I know).
Reactions: CodaMan
The middle bottom bolts really suck and the other bottom ones are no cake walk, but when the fender is removed you can do them with your eyes closed.
Yep, I agree completely. I did it the first time with the fender on, and that's a serious pain in the ass.
Reactions: CodaMan
I have had a noticeable engine roughness or misfire since she was new in '99(TJ). She's been back to the dealer on warranty but they never fixed it. At 124k it still runs the same. I chalked it up because I drive a Subaru most of the time. There so smooth running. The TJ was the misses.
My old 55 willys with the 134f head is so simple to fix. I been thinking of putting the TJ body on the 55?
I never really could feel the misfire, but it would produce a CEL. In most of California we have to smog vehicles every 2 years and you can't have a CEL.
I can relate. I had an XJ with the 0331 head and had to replace it myself. I'm familiar with this whole 0331 head saga.
Mine came on recently. It has been running pretty rough when I first start up, but smooths right out with a tap of the throttle pedal. I need to clean the IAC. On an 04, can you switch ignition coils? How about plug boots?
Mine threw the po303 code. Mine had the 0331 head, cracked on number 3 cylinder placed it My issues were heat soak after operating temp and park for ten minutes then crank back up, it ran bad rough for long enough to toss the code. I installed a louvered vent in my hood after cutting big holes to allow for heat to get out. No more issues. Motor runs 10 to 15 degrees cooler.
Reactions: DLJ54 and Chris
How does the exhaust valve rotate when there are no rotators on the top of the beehive springs? The valves are locked into place by the valve keepers and dont rotate. At least my stroker head, the head from my 98, the 258 head all had fixed retainers on all of the valves. I think that you had something else wrong with the head but I do not believe it was a valve rotation issue. Glad its working for you. Tim
I don't agree. Valves do rotate under normal operation albeit slowly. The rotation action helps keep the valve and seat clear of debris to ensure good sealing. That's why we lap the valves so the entire face of the valve will seal with the seat and not just one little part. And yes, some have rotate mechanisms to ensure they rotate at a predictable rate, but all valves rotate.
I have tore down 50 year old engines,and the valves had the original marks where they didnt rotate. If they don't have rotators the valves are not supposed to rotate.
Relief!!!
Hey bud, I’m having the same code and it’s been running me ragged. I have a question. How was the burnt spot causing the misfire? Like what about the head wasn’t adequate. Also if that is my issue, how much did it cost you doing it yourself?
A burn spot will cause low compression which in-turn can cause a misfire.
I replace the head. I purchased one for under $400 and replaced it by myself in one weekend.
Reactions: Rusty Rivets
Ok I’m going to do a compression test next chance I have to work on it. Did you do that and if so what was the conclusion of the test?
