Snorkel Recommendations?
That's the spirit! Mud is awful. :)
I just hate to be the one guy out of say 50 people to get hydro locked that is the one thing I absolutely do not want, no way! I'm mean you're pretty much talking about a new engine at that point.
I have done plenty of water crossings as well as ling drives through deep water with my TJ as well as my old CJ5. I have never used a snorkel. I did plan at one point a long time ago of making my own snorkel and found the attached write-up at another forum and saved it as a PDF.
I have taken my TJ with the stock air box as deep as the bottom edge of the headlights with no snorkel. I have always been very careful and always knew how deep before I went in. I friend of mine with a snorkel actually floated his TJ across a deep water hole.
Now with all that said and my years of water wheeling under my belt here is my 2 cents as far as water and Jeeps.
Think of water a cancer, basically you will not see any issues until later in life. Water eventually will cause issues with starter, AC compressor, clutch and wheel hubs. I have gone through 3 starter. My AC compressor has been making noise since 2010 and about 2012 it finally died on me. because of all the crap in the water and vegetation etc.. I had to replace my clutch because the pressure plate got clogged up with junk from the water. My 6Speed NSG370 transmission is also on its last leg because Jeep never added a breather hose it it and I never knew.
Make sure you check and extend as high up as possible all the breather hoses (2 axles, Transmission and Transfer-Case).
Belt pulley bearings will also have issues as time passes by.
Avoid if possible long water exposure meaning long deep water. Try not to get stuck in the water because you don't want your Jeep sitting still in deep water.
Going through a small stream or a water hole that is more like a quick dip is not bad.
Water playground
Clutch
Water playground
Clutch
View attachment 53175 View attachment 53176 View attachment 53177
Spot on with my experience as well. A Jeep TJ wasn’t designed for deep water and a snorkel doesn’t change that. Short fast crossings up to the headlights are okay, but if you ever come to a stop or stall in deep water, turn the engine off and get towed out.
This video was posted a while ago. But this is what it takes to water proof a willys jeep. A tj has to much electronic crap to even attempt
Stock as far as I know, many clutches don't let up when they should I suppose.
If true, it sounds like the clutches weren't working correctly prior to the water crossings where you've seen the fan chop up the radiator.
I couldn't say if they were or weren't, could also be the speed they entered the water. I can tell you ive replaced plenty of fan clutches for failing to release. Some are so locked up that they might as well be bolted straight through/no clutch.
Point is, there are a lot of items to consider when hitting deep water with your jeep other then a snorkel.
Reactions: jjvw
