Runnining with no hot air in the Jeep for a while now. Finally got around to digging into it. Found out the radiator was leaking so while i was in there went ahead and replaced it along with the thermostat. Also went ahead and flushed out the heater core. Before the outlet hose would not get that hot. Now it gets unbearably hot like the inlet hose. When running the engine to temp i have noticed that stays steadily below 210. Before the replacement there would be no hot air at all. Now its luke warm at best. I ran several flushes until the water came out crystal clear. I checked the blend door actuator, and it seems to be working as well. There are no leaks that i can tell so not sure where to go next. Could the water pump be out? Or am i actually looking at a bad heater core?
