Hope its going well and apologizes for starting another thread
from suggestion in the previous thread (https://wranglertjforum.com/threads/dana-35-gear-rebuild-advice.88641/), I have successfully done a minor overhaul of my dana 35 with new bearings and races, reusing the old shims. Currently I believe I may have over tightened my pinion by an 8th turn as my preload is at roughly 22-24 ish when I turn the pinion counter clockwise but comes down to about 20-21ish when I turn it clockwise. I'm unsure if this is maybe due to my adapters for my beam wrench being kinda loose and old but my backlash came out to about 6.5 thou...
Wondering if, 1. I need to try again with a new crush sleeve or if I can run this backlash 2. am I using too much compound? 3. Not sure if I am pressing hard enough on the carrier while spinning the pinion since I'm doing all of this under the jeep on my back.
Thank you in advance!
- Rei
Gear Patterns:
- Rei
Gear Patterns:
