Howard Fabworks Half Doors
Wondering if they might be available without the jl hinges... or with the tj hinges? Shouldn't be difficult to change up?
That looks like a JL hinge on the door going into a TJ body hinge to me? Just that the JL hinges apparently have some way to lock them
Reactions: suicideking
"-Modified Jeep JL hinges - (Locking hinges to prevent theft). ***factory door bushing must be removed for install. new bushing included that adapts to JL hinge.***"
The way I read it, removing factory TJ door bushing means you cant use your other TJ doors with TJ hinges. You're committed to the modified JL hinges, now you have JL bushings.
  • Sad
Reactions: lBasket
Oh I missed that. I saw the hinge part looks the same but I guess you have to change the inner bushings
Weird. Why would someone put that much effort into fabbing half doirs only to require a special bushing with inability to go back to full TJ doors?
Reactions: L J
If you don't know, then why did you call it an inner? It's a bushing, not inner, not outer, just a bushing unless it resides in close proximity to another bushing around it.
Maybe I just wanted to be sure other people knew it wasn't an outer bushing
Reactions: hosejockey61
Nice looking doors, I don't like that you have to drill into the door panel for extra storage, if the PRP bags can be added in that would be a better option to me.
Reactions: bbaldwin237
