I understand that shimming is required to set the pinion offset correctly. What I haven't seen mentioned is how to tighten down the pinion when checking the offset. As you all know, a crush sleeve and precise torque settings are used when tightening the yoke nut. Do I need to go through that procedure every time when checking pinion offset? Seems like that would require a new crush sleeve every time so that doesn't seem like a good way of doing it.
