I can remove the entire spool valve assembly and reinstall it in about 30 minutes. The other filter requires supporting the engine, removing the passenger side motor mount, removing a belt tensioner and a pulley (I've forgotten what it goes to), as well as removing the power steering pump, all just to get to the second filter (screen). I did that the first time, and while it was fairly contaminated, it was nowhere near what the first filter was, which was absolutely plugged solid. Therefore, I decided that I will use the "easy access" filter as a gauge to determine what the engine's doing, removing it as many times as necessary over time. The second filter will likely only get pulled one more time, once I'm satisfied with the results of the first filter's condition. Does that make sense?
Thanks for looking into it, though, and sharing it with me. Nice to know some folks have my back on here! (y)
Take a couple pictures next time you're in there. I'm curious to see what your working with.
Why the hell can't auto manufacturers just build a damn car with IRS that you can actually make the necessary adjustments to without having to modify the suspension? Grrrr...:mad:
Built for the modern American market. Get 'em loaded up and the chamber goes positive. ;)
Actually, now that I post that, I think I see why everyone is driving trucks now. :LOL:
The actual answer is financial. Back in the '90s Honda, and several other Jap manufacturers, used double wishbone suspensions front and rear. Stock suspensions had quite a bit of adjustment, and with a few bolt-on aftermarket parts, you could really dial in a Honda from the 90s. With Hondas, the Civic went first and switched to a McPherson strut front, trailing arm rear with the 7th gen in 2001, and as far as I know, that's what all are running today. That was done because it's cheaper than a double wishbone setup, but it comes with sacrifices.
(I snagged this post from another thread. The pictures really tell the story...)
Not actually my vehicle. It's the neighbor's dad's 2005 Honda Element. It's got 254K miles on the little K24. The thing went into "limp mode" on him, and was throwing a code for two cylinders misfiring, as well as a P2646 code, which is associated with an oil pressure reading. I did the tune-up (plugs and coils), and the replaced the screen in the spool valve solenoid, as well as the one on the other side of the block. Apparently, someone hasn't been keeping up on their oil changes! :rolleyes:
The pictures tell the story. You can't even see light through the one screen. Anway, it's done, and I tooled it down I-5 at 80 mph (after an oil change...) ;)
While I'm on a negative camber kick, can someone please tell me in what world where this is cool? :rolleyes:
View attachment 666098View attachment 666100View attachment 666099
'Nuff said...
"Stanced", that is one of the dumbest car trends, so far. I'll bet their boyfriends drive squatty-potty trucks, too. :rolleyes: When my son sees one, he'll typically yell out "look at that broke car", which is all him. With the exception given to old VWs, I agree.
Speaking of squatty-potty trucks, I had to start watching what I say about them. We were at a local restaurant eating outside and one just happened to ride by, to which my son yelled out "Dad, look at that gay truck". :ROFLMAO:
