My 2000 TJ 4.0/32RH Build Thread
BlueJayTJ
Christian Nibert
Lifetime Supporting Member
Bassfield, MS - 39421
I just realized that I have had my TJ and been on this forum for quite a while now and have not done a basic thread to keep up with where it started and everything that I have done to it so far. I will probably just start with a photo dump and pickup from there. Many years ago I had a 1970 Toyota FJ40 LandCruiser. I love the Safari look and also am a big fan of anything retro/vintage. My build is taking some styling cues from the FJ40. I plan on getting the Gr8Top TJ Safari Cab Full Length Hard Top https://gr8tops.com/shop/jeepmodels/wrangler-tj-2/tj-safari-cab-full-length-hardtop , Fjallasport Jeep Wrangler TJ/LJ High Line Fenders https://www.fjallasport.is/product/jeep-wrangler-tj-lj/ , Verozza Carbon Fiber Heat Reduction Hood (Hi-Fenders) for the Jeep TJ or LJ https://genright.com/shop-by-vehicl...w1J3rfggmgOgrzSxpOHxnNL9wZYOhjoOxl49-a08sErTm , and Rat Rod (Series 66) Extended Sizing Gloss White 15x7 | 5x4.5 | -6/3.75 | PART# 66-5712 Wheels https://www.uswheel.com/wheel/11992/us-wheel-rat-rod-series-66-extended-sizing/?finishID=51. I also have a Warn 8274 Winch that I am in the process of rebuilding. Eventually I plan to swap in a 5.7 Hemi and make a sort of AEV 570 TJ Clone.
Well he's got points with me.... There's a Hemi under the hood...
Reactions: SuspectLJ
I will be picking your brain when that time comes. I have a 5.7 Eagle Hemi out of a 2012 Challenger, just needs to be rebuilt. Have most of what I need to rebuild it, just haven’t gotten the transmission/transfer case and all the other goodies yet. Yours is pretty mean lookin for sure 😎
There are a few of us who have a Hemi swapped into our rigs on here.
Take a look at this thread: https://wranglertjforum.com/threads/gen-iii-hemi-swap-into-tj-reference-guide-swap-info.46347/
Just to note, the Challenger engine will be a bit more challenging to put into a TJ frame. Getting the accessories to clear can require notching the frame. Not saying tit can't be done just saying it's a bit harder. But the Eagle heads are well worth it compared to the older non-Eagle engines.
Jeff (@NashvilleTJ ) both have older engines. But I updated mine to Eagle heads before installing it.
Gassiper did a 6.1 swap and there is another member who did a 6.4 swap but I can't remember their name right now. There are a few others.
Ran into an issue with the mirror brackets when trying to install the snorkel, so I will have to put it on when I get back home in February.
I still have a couple of weeks before I am home from work to do anything else to the TJ, but I have finally decided that I am going to do the "DIY AEV style Highline fender modification." I have been contemplating it for years and it is the main reason I have not put the snorkel on yet, but now it is killing me not having my snorkel so I am just going to pull the trigger. After researching several build threads for years (except for the HigherGround4x4 thread, I would give almost anything to be able to see that for myself) I have decided to split the pinch weld at the top of the fender, separating the inner and outer fender so that I can leave the inner fender in the factory location and only move the outer fender up. I understand that doing this limits my ability to "stuff" the tires at full flex, but right now I only have 31x10.5r15's on the factory grizzly wheels and even when I go up to 35x10.5r15's with the Old Man Emu 2" lift springs and this fender mod, I still wont need to be able to do that because I live in South Mississippi and mainly trail ride in Pine Forests and hit the occasional sand bar. The main reason for me deciding to do it this way is to leave the engine bay as factory as possible. Anyway, if anyone has any words of wisdom for this modification, especially any pictures that will help, by all means, send them my way! The only part I am remotely worried about is bending the fender around the headlight portion of the grille.
Reactions: lBasket
