Correct way to bolt stuff to the floor?
Moab
TJ Expert
Bohol, Phillipines/El Segundo, California
I need to bolt something to the floor. I hate to do this. I don't like drilling holes in sheet metal. But I have no choice.
I assume better stainless hardware. Bolt, two washers (top and bottom)and a lock washer and nut or nylon locking nut. Going to spray the hole with paint. Then silicone before placing the bolt?
Any other advice?
Any other advice?
Since I can’t get a wrench on the nut under the floor and on the bolt head on top at the same time I use nutserts.
In 90% of the cases one can start a nut and grab it with vise grips and tighten it while the VG's are wedged against something. Far as washers or?? it depends on what it is and how heavy it is. I might plate the backside. Far as SS bolts, eh..sure. Our hardware supplier always told us their all G5 rated, straight from China. Fine, but they gall easily if tightened up a bunch.
Reactions: speeding_infraction
Any other advice?
Don't use stainless unless you really don't care about rust. The stainless fasteners will be fine. But they will massively accelerate corrosion of the surrounding steel.
https://en.wikipedia.org/wiki/Galvanic_corrosion
Zinc plated or galvanized steel fasteners are your best bet.
Stainless is good when the bolt itself is subject to corrossion and the part around it isn't a concern.
But near the ocean with salt in the air, I would also go with that "gold" plated zinc chromate or zinc galvanized to protect the body.
Any other advice?
I wouldn't use stainless, for the reasons mentioned. Also would not use a nylock. Spray the hole and bolt liberally with Fluid Film before and after installation. How big of a bolt are we talking about? Just one bolt or multiples? Where in the floor?
Black oxide is a poor choice for use outside. It was minimal corrosion resistance. It will start corroding as soon as it sees humid air, let alone rain or salt...
Good, that means the nuts I used for the transfer case linkage on my truck definitely won't come loose🤣
Reactions: ColoJeep and sab
