Those of you who follow my build thread know that I believe I've likely just smoked my second ring in pinion in my shaved 14-bolt. The last time I did this, the ring gear was fine, but the pinion gear - not so much:
It did not fail, but started making noise - just as it is now.
As noted I run a shaved 14-bolt, which requires the ring gear be milled down from 10.5" to a little over 10. Both sets of the failed R&P's have come from Yukon - because they sell a shaved version of the ring gear which makes it simple. This despite having some knowledge about the quality issues with Yukon gears in general.
Revolution Gear, with their Korean manufacturing, is widely regarded as the go to here on the forum. But, Revolution does not offer, not will they mill, a 14-bolt ring gear for a shaved setup. For me to run a Revolution gearset I will have to go through the hassle of getting the ring gear milled. I've not yet found a local place which will do it.
So here is my question: Is the improved quality of the Revolution gearset worth the extra milling hassle compared to just going the easy route with the Yukon gearset?
Also, does anyone think going to the Revolution pinion will stop the next failure? I do not, but I'm looking for any advantage.
I'm starting to think there is something to the whole "5:38's are weaker" thing, which I know has been discussed here and discounted. But, I'm now 2 for 2. I jokingly now refer to my rear axle as "The Sissy 14-Bolt."
Not to say these 14-bolt pinion gears are small, they certainly are not:
After smoking my old Pro-Rock 60 5 times, I built this 14-bolt thinking I was not going to be dealing with this any longer. Well, crap..
