Preventative maintenance while fuel tank is dropped?
Cumsterdump
Arizona
hoping to drop my fuel tank very soon to install a new regulator, pump, and screens. but am curious what other wear items i should deal with?
i’m pretty sure there’s some kind of valve on the fuel neck which is why it sometimes clicks off at the gas station. i think id want to do that
any O rings or gaskets anywhere i should deal with? new filler neck? repaint anything?
i have a 2001 incase anything is year specific
Just the one gasket under the fuel pump assemble that should come with the assembly, otherwise everyting else is contained within the fuel tank proper. Just check the condition of the fill and vent hoses to the filler inlet assembly at the gas cap.
Reactions: Christian.mers
i’ll look for one. i’m not replacing the entire assembly just the pump screens and regulator
I found the new oring at the dealer, cheap too. I bought an OEM Bosch pump and fitted it into my original assembly.
Hint: lay your plastic ring on a dark surface in the Arizona sun while working on the other stuff and it will thread back on easier.
I you happen to know anyone with a motorcycle rolling jack they are the Cats meow dropping the fuel tank on a TJ.
I got the Aluminum one from Harbor Freight and it has come in handy several times.
Reactions: ColoJeep
