2000 4.0 Fuel Pressure Question
MayzesTJ
North Carolina
Hello,
When turning my key on. Pressure primes to 50, then after a few seconds drops to practically 0. Fuel pressure should hold for a few minutes around 50 correct? When running it’s 45-50 no issue. Any suggestions
Yeah that's not good the most common causes include a leaking fuel pressure regulator, a faulty check valve in the fuel pump, or leaking injectors.
Hello,
Are you having starting issues.
You can just replace the pressure regulator on top of your fuel pump assembly.
