Clayton front track bar or JKS?
jxv1247
Stamford, CT
In need of a new front track bar and Clayton is local to me. It appears their system uses a drop bracket along with a drop pitman arm . It seems like they have been using this setup for quite some time. Is there any real downside to this besides bump stop extensions (already have 3” extensions )?
Or would I be better off with something like the jks hd ogs128 bar ?
Why pay hard earned money to lose travel and gain bumpsteer?
Reactions: Chris and jxv1247
I have Clayton on one of my Jeeps and a few other parts on various other vehicles. While it’s doesn’t receive the most love, I have never had an issue with any of the parts they have sent me.
They offer a track bar without a drop bracket. That would be my preferred choice if I was to purchase from them.
Track bar with 5/8 bolt
I also have ran JKS and RockJock. Both great with RockJock being the preferred choice. JKS is less and bent correctly.
JKS $255.95
Photo is from Clayton’s website.
Reactions: jxv1247
Thats a great choice if you want it to hit the gas tank skid and bind up on droop so you can barely get coils out. I chucked it for a 10 year old rockjock and have no regrets
This is what I don't like about the front RC bar...even less flex when I swapped the bushings for larger bolt size. Maybe time to try the currie...
This.
I had RC track bars front and rear. The rear smashed into the tank skid and caused binding in the rear. Swapped it for a JKS and have not had an issue with it coming in contact with the gas tank skid. The JKS has a kick towards the front coming off the frame mount to clear the gas tank skid.
My front RC track bar got tossed for a Currie I found on Marketplace for $150 new in the box. I didn't realize how much bindage the front RC track bar cased until I swapped them.
When I built my Dana 44 with the Jeeps West brackets a few months ago, I have clearance,not much at full stuff but clearance nonetheless,The clamp bolts did hit it but I just flipped em and problem solved
I wasn't limited on droop,The axle would just free fall when no jack stands were In place. I just have to give it a good push with my hands to get it where I want but that's what's it like with any TB with rubber joints when your installing springs,taking em off etc.
Edit- I didn't struggle with that is what I'm trying to say
The moog joints seem to do their job, The TB is an alright piece,Just take out the shitty bushings it has and make it work and it'll be fine 🤷🏻‍♂️ I also had the flexibility to move brackets around when I built this axle so I was able to accommodate any clearance issues
Once I start on doing my ford 9" swap here pretty soon I may mess with using a Core 4x4 unit,It has Jhony joints on both ends and it has the bend like a JKS or currie from what I saw and it's cheaper
Just brain storming
Reactions: Rickyd
