When I built my rear axle,( Wagoneer 44) I installed new bearings when installing the new shafts. That lasted for about three years and earlier this summer I found the driver side had in and out play. I pulled the shaft and found that the bearing was bad I replaced It and did another trip to Rubicon and a few other trails and decided I probably needed to replace the other side and the brakes as well. When I pulled the passenger side. The bearing was completely blown out with a ton of play and the driver side was for lack of a better term. Was bent and misshaped.
Any idea what could’ve caused this before I throw it all back together I’m going to replace the flange bolts along with the a new axle retainer plate
