Hi all, I have a 2002 wrangler. I’ll start off by saying it has a new battery and new ish alternator, I don’t know exactly when the PO put it in but it has a date code for 2013. For the first 1000 of ownership it was great. Then driving home one day the battery stopped charging and the gauge was pointing to the left white dot. At home I checked grounds to see if that was the issue. From what I could tell, everything was grounded correctly. During this time, I unplugged the connector on the alternator going to the PCM. Plugging in this connector makes the battery charge as usual. GREAT! Or so I thought. This lasted about 20 miles before the problem persists again. I have gone through about 6 cycles of unplugging and plugging in this wire and it’s the same result everytime. I have tried cleaning the connections with a toothbrush but I could try harder. Is this caused by a bad connection or something else? Thanks.
