That's a good sign, means they think they have really dumb customers, or they trust their technicians to do stuff right.
And no liability insurance.
you just say "six seven" and hilarity ensues. I'm too told to understand it, but not too old to participate correctly.
The kids have been saying it, it proves they are mental midgets. Rizz skibidi no cap or something like that.
Thank you once again. These things are good to know.You should have asked. The inner axle seals have a stamped metal forcing cone that makes it almost impossible to damage the actual seal. If the axle shaft came out, they didn't take a hammer to the splines and create a sharp edge or roll it around in some sand and shove that into the seal lip, the chances of a damaged seal upon reinstall are next to zero.
What does happen 99% of the time is the diff is overfilled. Correct fill height is below the bottom seal lip when the shaft is removed. If it is above, then the oil in the diff runs out into the axle tube and eventually makes its way out the end and the owner reports "puddles" from a "bad" seal.
We do lots of brake kit installs. We do one side at a time, we raise the side we are working on higher than the other side because I don't like that phone call and I don't like trying to explain to owners that there is nothing wrong except a delayed appearance of all the extra oil they wanted to put in.
This is what the inner seals look like. There is practically no way to damage the seal since the forcing cone lines it up and shoots the shaft right through the middle of the seal. If you paid me to make one leak, it certainly wouldn't be my first thought to shove a just removed shaft through it.
I built a rig for a guy once. We put near new, sub 100 mile Dana 44's built by G2 under it that he traded his Rubicon 44's for. He drove it home, drove it around for a month and then called me to ask when he could drop it off to get the leaking axle seals replaced. Sorry buddy, I didn't install the seals, build the axles, or anything else plus this was a swap and there is no money involved for you getting the axles in place of yours.Thank you once again. These things are good to know.![]()
Huh?! Run that by me again…I had a real capable shop do the same thing….poured.
All I know is their drip is bussin, fr fr.
I don’t step foot in a shop. If I get to the point I have to I’ll sell all my rigs because at that point it’s time for me to move out of this hobby.
"six seven"
Rizz skibidi no cap
no cap, but 6 7 is skibity ohio
My experience and would be my advice, take these details and education. Being a knowledgeable customer, if you’re not a jerk and never listen, isn’t bad.
Also, I wouldn’t go in hot. They’re wiling to stand behind it, just make sure with some pics what went wrong.
Coming in hot, usually creates a worse situation.
There are times it’s needed, but that’s the backstop for me.
I've been on both sides of the counter and I can assure you, I am aware. I worked as the fabricator in a high end custom car shop, and worked with customers as a job shop machinist. I also have worked helpdesk in IT. much like in electronics, heat means resistance lol.
This is the same shop that caused this issue:
Basically, I went in for a tire rotation and a front axle shaft u-joint. I didn't have a press for the u-joint so I had them do it. Someone didn't get all the lugs tight and it drove great for about 70 miles before I got noise and vibration, then about 10 seconds after the noise started, the jeep converted to tricycle mode and the front tire rolled off into the sunset. No one was hurt, damage was pretty repairable. No sheet metal damage, just fender flares and everything attached to the knuckle.
Once this happened, I tried not be a dick and I worked with them to find some solutions we all were happy about. In the end, I saved them a chunk of change by not using the emergency tow truck UHP called to get it all the way back to their shop, I got another set of tires mounted and balanced for free to avoid a rental, and they happily replaced all 4 fender flares and the 2 mud skirts, plus all of the other damages. They won because I easily could have cost them a couple thousand more with no material benefit to either of us, and I won because I got the original issue fixed plus my fender flares replaced for free AND my samurai tires mounted and balanced for free.
I came out ahead overall minus some PTO, they came out about as good as they could hope for in the situation. Coming in hot probably would have had worse outcomes for both of us.
I think a reoccurring theme here is I need to buy a damn press lol. Also, a TJ drives pretty good on 3 wheels still and makes a pretty neat fireworks show if you drive it wrong enough.
FWIW, I helped Dale (on this forum) rebuild his Dana 44 and we had two leaking axle seals.... TWICE!
I've installed many seals in my day and never had an issue. One leak, okay - maybe I screwed up or there was a defect that I missed during install, but four leaks?? No way...
The first two leaks were with AutoZone brand seals. The next two were Timken. Shafts were fine and super smooth, and all seals went it perfectly.
Saw a similar issue noted on a few pages where the only "fix" was a set of Spicer-branded seals. Did the axle seals a third time and viola! Not even a hint of a drip! Needless to say when it came time to get parts for my daughter's JKU Dana 44 rear that I'm rebuilding, I absolutely went with the Spicer seals (and bearings and retainers)!!
WELL THEN, the saga continues.
That didn't last long. Its leaking again. I guess this is a case of 'if you want it done right, do it yourself.' I went outside to start measuring travel for the lift I'm going to be installing and noticed I smelled gear oil. Looked down, and sure as shit its drooling again. Puddle in the dirt driveway levels of leak. Not nearly like it was last time, but I want NO leak, not a lesser leak. I think I'll give them a call tomorrow and see what they're willing to do for a refund or.... something. Either way, I'm installing new parts myself. I think the O'Criminey auto parts they used have, yet again, bit me.
Same story on getting a new front output shaft seal for my 231. Tried O'Reilly's house brand, nope. In the end I swapped the front case half and then left the twenty plus year old seal...that one doesn't leak.
