A stock TJ has only one alignment setting, toe-in. And it's easy to do it yourself.
This is a way-too-long thread on the subject: https://wranglertjforum.com/threads/how-to-align-your-jeep-wrangler-tj.85/
Read the first page. Ignore most of the rest. There is a LOT of discussion about proper measurements. Just make it 1/8" at 24" or 3/16" at 36", and ignore all of the nonsense about tire size, which has nothing to do with toe-in measurements.
Get both ends lowered before you worry about needing adjustable track bars.Right. Appreciate this info. But everything up front is back to stock, I haven’t done the back yet, but when I dropped it down it would appear that my axle is favoring the drive side by about an inch. How is that possible?
Get rid of those crappy tubular arms too.they are possibly longer to compensate for the lift. Stock flexes better,rides better and won't rip brackets off like those can.
When its all back to stock jump on the bumpers to settle it before looking at axle placement. Better yet go for a short drive to settle it.you can measure from the inside of the tires to the frame.it removes the guessing if the body is shifted on the frame from the equation.
Also,the toe in will change with the ride height. That needs adjusted
I have replacement stock front LCAs on there now. And will be replacing the tubulars on the rear as well. Had to cut out both front axle end LCA bolts. Found a carbide tooth Dewalt oscillating tool does well with the bolts if you have the 10 solid minutes for it to grind away at each bolt, and are willing to fork over the $25/each for the extreme metal Milwaukee ones.
All good advice to wait until I have the whole thing back down to stock height. Ultimately if I need to I’ll just get an adjustable track bar, but I don’t see how I could need one with stock everything. View attachment 651544View attachment 651545
Yeah I'd clean it up, v groove it with a grinder or die grinder, weld it up and grind it smooth.
I'd pretty much say owning a welder is pretty much a slightly advanced but still necessary tool for Jeep mods.
I recently bought an Everlast plasma cutter and am impressed with their cutters and welders. Going to buy a TIG box for aluminum from them one of these days.
Oxygen Acetylene is your friend.
Drill it out, bigger and bigger, until what's left will crumple.
