How do the factory pumps actually function when the locker switch is engaged?
Do they stay on the whole time and are regulated to 5psi or do they turn on and shut off when they hit 5psi and holds pressure?
How do they decompress to unlock, does the pump have an integrated valve to vent pressure when the locker switch is disengaged?
Instead of purchasing used pumps for $400 that look like they have been sitting in a lake for a few years I am looking at making my own setup. I am planning to use a small 12v air pump capable of 30psi and a boost pressure NC switch that is set for around 5psi to shut off the pump when it reaches operating pressure. The pump is like $5 and the boost pressure switches are about $40-80 so quite a bit cheaper than used factory lockers. Just trying to make this setup function as close to the factory lockers as possible.
