Wiring multiple accessories
Christian.mers
Point A to Point B
Huntington, West Virginia
How are you all wiring all your accessories?? Multiple lights, A/C Compressor, all the crap. Are you just running to the battery (positive and negative)? Fuse block? Inline fuses?
Right now I’ve got stuff wired up to the battery but I don’t want a bunch of wires all around my battery.
I have a fused accessory relay box under my brake booster. It's powered off the battery, but the relay trigger is via a tap-a-fuse in the glove box fuse area, either on the radio (for ignition switched power) or the fog lights (which I don't have, but gives me constant 12V). I know @macleanflood has something similar, I'm sure many of us do.
But your A/C compressor should already be wired into the PDC.
For switching an accessory relay box is the cleanest way as @hear mentioned. There are several versions on Amazon, as well as prewired switch kits ranging from value places like VosSwitch/Auxbeam all the way up to $$$ like SSV Works and SwitchPros.
I don't have the LJ to that point yet, but here's the rest of my setup in the JL (the Aux Relay Box is just black plastic mounted by the brake master cylinder). I mounted a BlueSea CB and fuse block to a metal plate. Positive mains run from the battery to those, and the grounds are all bussed underneath off a bolt on the bottom of the plate. The breaker is for the twin compressor.
I ordered the S-POD 6-circuit switch panel that replaces the trim above the rear view mirror. it works great, except I'd prefer if I could make it turn on/off with the ignition and avoid risking running the battery down. my battery is very old so i'm not sure if it going dead after sitting for a month is due to the age, or the spod drawing power to run the bluetooth connection.
Reactions: Christian.mers
View attachment 649745View attachment 649746
Great setup, I like how you used that empty spot that we all seem to have
Pretty cool little bracket. Might have to fab something up for sure
I think it’s discontinued,how long ago did you order it?thanks
I just got marine terminals from Walmart and used the wing nuts
A few months ago I think. Definitely this year. I seem to remember i had to find the page via google as it wasn't showing up on the TJ product page. it looks like you can still order through 3rd party sites but no telling if they'd actually build it for you. When i ordered the site said to allow extra time to build it since you could spec different color lights in your switches.
I actually have another one in the garage i bought on FB marketplace that is for the earlier year models before i realized there was a year break. I'd sell it but it would definitely be a pain to ship.
