Tool deals
About This Product​
The new MILWAUKEE 1/2" Stubby Impact Wrench delivers the Most Power, Is Lighter Weight & More Compact while delivering 50% Faster Application speeds. Leveraging POWERSTATE Brushless Motor, The Stubby Delivers 0-3,000 RPM with up to 550 ft-lbs of Nut Busting Torque, allowing the removal of the most corroded and stubborn applications. This Milwaukee solution delivers on performance and size, at only 2.2 lbs bare tool. Users will experience less fatigue throughout their work week while fitting into tight spaces and allowing access where larger impacts can't fit without using additional accessories or disassembling components to reach the desired fastener. Equipped with Tri LED work lights to illuminate your work area without the frustration of shadows. 4-Mode DRIVE CONTROL for greater precision and customization to your desired power output, including AUTO SHUT-OFF that applies no more than 15 ft-lbs of torque for hand-tight applications that prevent overtightening when in forward. In reverse, bolt removal mode will slow down the RPM once the bolt is free to prevent bolts from flying around your work area. To change the modes, it is a single-handed operation. By shifting the forward-reverse shuttle into neutral and double-tapping the trigger, you will be able to change modes effortlessly.
Highlights​
  • Lightest Weight & More Compact
  • Up to 550 ft-lbs of Nut-Busting Torque
  • 2x Faster Application Speeds
  • Mode 1 RPM: 0-930; Mode 2 RPM: 0-2,100; Mode 3 RPM: 0-3,000; Mode 4 RPM: 0-3,000
  • Tri-LEDs deliver high definition lighting to increase workspace visibility with less shadows
  • 4-Mode DRIVE CONTROL provides greater control over output speed and power. Includes auto shut-off and bolt-removal mode
  • Auto shut-off mode prevents over tightening and increases productivity by applying no more than 15 ft-lbs. of torque.
  • New Battery Isolation System for secured battery connection and reduced vibration transmitted to the pack
  • Compatible with all M12 batteries & Chargers
  • Friction ring socket retention system: Reduces downtime on applications involving frequent changing of accessories
  • Click here for more information on Electronic Recycling Programs
  • Return Policy
Product Information​
Internet #​
Model #​
https://www.homedepot.com/p/Milwauk...tery-Pack-2-Pack-2563-20-48-11-2412/336305528
It looked funny to me, so I had to look it up. Authorized is American English and Authorised is British English. This company is located in KC?
Reactions: John Cooper
Just a heads up, since it's a Milwaukee, I grabbed the newer M12 Fuel 3" Cut Off Tool (2522), and tried to use it to high-line the hood. No go with the sheet metal and would stall an inch or two in, probably not worth returning but it's basically a dremel with a big wheel.
  • Sad
Reactions: Apparition
Agree and had the same experience when cutting my fenders. It is the only M12 Fuel tool that I am disappointed with across about 8 that I have.
Reactions: GATORB8
When I do the high line fenders its gonna the angle grinder with a cutoff wheel so I dont have that issue.
I have the older Chicago Electric version of this and for what it is it works ok. It’s not the most powerful, and has an internal breaker in it that trips when it works too hard, but it’s just a button on the bottom of the unit so I just keep the paddle pressed and tap the button if it pops and continue on. I used it for my hood. Seems to have a little more finesse than the grinder and isn’t as noisy or cumbersome as the pneumatic with the air hose and has similar power. I use it quite a bit and for the price it’s a welcomed tool to my cabinet.
https://www.harborfreight.com/6-amp...tool-59248.html?hftm_sc=203&utm_source=google
I wonder if the Bauer is better than the Chicago Electric one?
I know most of the Bauer seem better quality in what I have bought.
I wondered that too, and for $35 I’ll probably pick one up next time I’m there. I broke half the paddle switch off my CE one and that had the safety on it so if you set it down on the paddle it turns on. Good excuse to try the Bauer version and if it has more power than the CE one then that tool will be a home run.
  • Love
It's like Northern Tool read y'all's minds. How bout their Ironton for half price ($15).
https://www.northerntool.com/products/ironton-3in-electric-cutoff-tool-high-speed-6-amp-5797362?cm_mmc=Google-pla&utm_source=Google_PLA&utm_medium=Metal Fabrication > Metalworking Grinders&utm_campaign=Ironton&utm_content=5797362&ogmap=SHP|PLA|GOOG|STND|c|SITEWIDE|INTRADE|MetalFabricationOwnedBrands|{adgroup}||19587274510|145151520933&gad_source=1&gad_campaignid=19587274510&gbraid=0AAAAADpPfbPHJliJgT-m75oobwkYnjsw3&gclid=CjwKCAjwr8LHBhBKEiwAy47uUr9lUUjwccnZ_F6sfr7aPf6iU-efpWlpAIGZMUDs1_wDe6Rm0tcNURoC7pAQAvD_BwE&gclsrc=aw.ds
