Thoughts on Torx and hex driver sockets
Wait, so I’m not an idiot???
For the smaller stuff you can't beat German made Wiha. I also have a full set of their hand Torx screwdrivers, they are tough and the handles fit your hand perfectly and are easy to grip.
Wiha is made in both Germany and Vietnam, It's the German made ones you want, although I can't say first hand if the Vietnamese ones are inferior because I never tried them.
https://www.wihatools.com/
I am pretty sure they are T45. Worked on semi-trailers for three years. Replacing the wood floors was an easy task, as long as the screws weren’t rusted to the cross members or the heads weren’t stripped out..
Always thought some chunks of that flooring would make a great workbench top surface.
Reactions: John Cooper
Yep T45 they are. I never have seen an easy floor job, maybe its because I always got to work on worn out trailers .... .. :ROFLMAO: I was used to maybe 1 out of 100 screws not breaking
I did work in a trailer manufacturing plant and the floor drill and screw machine made the job easy.
Lord Buck rivets and bucking is the worst no matter how much hearing protection you wear!!
Rust. Any truck trailer that's spent a length of time in the Northeast or near the coast.
Thankfully the trailer shop I worked in was in the Northeast...:ROFLMAO:
Funny I hadn't thought much about that job in decades.
I can't say I enjoyed it. I remember bucking from a ladder sucking doubly. Mindless, but you had to pay attention. If the bar came off in the process you could have problems and some explaining to do. Couldn't say how many rivets are in a post or panel, but I recall the process feeling endless to my early 20's brain. Did a few roof jobs while I worked there as well. Sardine cans. :D
Gear Wrench
Good affordable tools.
For combo wrenches, I used to keep 2 sets when I was a mechanic and do now, again. About 10 years ago, I needed a second set of metric wrenches in a pinch and purchased a set of Gearwrench flex head ratcheting combos from an auto parts store. They worked at the time and have actually held up pretty well. No skipping teeth yet.🤞
I have some Torx and Security Torx bits from Wiha, and they are very high quality. I've used them on my modified step slider project (96 Torx or Security Torx fasteners), which I installed and removed probably five times during that project. I started with other brands of bits and they gradually twisted. They still worked, but there was a noticeable helix angle that developed. In contrast, the Wiha stayed straight as a rail. I generally use impact for loosening and hand tools for tightening (I like to feel for yielding.) The impact loosening didn't seem to twist the cheap bits - probably because it's only a few hammer impacts and they are pretty loose. They only twisted when tightening by hand, and I didn't tighten any with impact.
And, as a crazy coincidence, this just showed up in my email today. Apparently it's National Tradesperson Day (it's hyperlinked):
No, I don't work for Wiha - just passing on a good deal. ;)
I have used a set of snap on torx sockets for years, and they fit the fasteners well, and they are pretty durable. I have been looking at the Gripedge torx, and hex sockets, they appear to work as advertised. Lots of video reviews on them. There are a ton of partially rounded out torx fasteners on my jeep, so I will probably give them a try.
I went through a similar debate with myself a while ago. I landed on two sets:
Neiko - Chrome Molybdenum steel (For everyday use)
https://www.amazon.com/dp/B007SX10NS?tag=wranglerorg-20
Lexivon - Drop-forged, heat-treated S2 alloy steel (For impact use)
https://www.amazon.com/dp/B07M9ZF35W?tag=wranglerorg-20
Correct or not, I based my decision on the following research:
Chrome Moly (4130/4140) vs. S2 Alloy Steel​
PropertyChrome Moly Steel (4130/4140, heat-treated)S2 Tool Steel (drop-forged, heat-treated)
Composition (wt%)~0.3–0.4% C, 0.8–1.1% Cr, 0.15–0.3% Mo, balance Fe~0.45–0.55% C, ~2.0% Si, ~0.3% Mo, ~0.2% V, ~0.4% Cr, balance Fe
Tensile Strength95–160 ksi (650–1,100 MPa) depending on heat treatment225–285 ksi (1,550–1,950 MPa)
Yield Strength75–130 ksi (520–900 MPa)200–250 ksi (1,380–1,720 MPa)
Hardness (HRC)~20–35 HRC (can be up to ~50 with special treatments)~50–62 HRC (after tempering)
Toughness / Impact ResistanceVery good; resists fatigue and cracking under cyclic loadExtremely high shock resistance (designed for repeated impacts)
Ductility (Elongation %)~20–25% in annealed condition~10–15% (lower ductility, more brittle if over-hardened)
ApplicationsRoll cages, driveshafts, suspension links, axles, gearsScrewdriver bits, chisels, impact sockets, punches
Well, after much reading of the responses here, research and quite a bit of waffling (SOP for me when buying things), I have formed a course of action.
For decades my preferred hand tool brand was S-K when buying new (80's-90's) and my stash was mainly that with a smattering of MAC and Snap-on in the end. To date, I've never broken anything from any of them, and that even goes for used tools of those same brands I picked up a long the way.
Recently I've been hunting down older used S-K pieces on Ebay to fill in gaps in my older sets. Decided to take a chance and research S-K "vintage" hex and torx socket sets and, sure enough, I found some of the classic sets for sale (the type with replaceable bit heads). I've got the metric and SAE hex sockets buttoned up and on the way, the Torx are an auction so I'll have to bid.
Not sure why it didn't strike me sooner but I guess the couple of remarks on MAC, Snap-on and having old sets that are still going gave me the backhand I needed to wake up and remember S-K made them as well. Duh... 😜
These are all standard use, not impact rated, but I think I'm alright with that.
I've related this before but Kat brought home a pretty red Phillips #2 from the Salvation Army during one of her clothes shopping trips. I had no idea who Wiha was but I gave it a try. In short order, it became the only driver in that size that I used. That was about 15 years and 1000's of screws since. It it just as crisp and clean in the driver recesses as it was the first day I used it. I purchased another one just like it in case I lose the first one.
They also have a most excellent large flat blade. Seems odd, right? Well, any time I go to work on anything under a rig, I grab 3 tools. Medium ball peen hammer, large drift, and a large flat blade screwdriver to use as a small prybar. To date, the Wiha is the only one I haven't broken and I have a nice collection of many other brands I've ruined including several vintage professional Craftsman.
https://www.wihatools.com/products/softfinishr-heavy-duty-slotted-12-0
