Do you have a winch? How often do you use it?
Just yesterday as a matter of fact.
I'd say I'm in the camp of having it and not needing it after dropping a tire into an old box culvert (google it if you don't know what that is) and thankfully had a friend with me in his own rig to pull me out otherwise it would have been a very long walk.
I definitely feel a bit safer and more capable having a winch, but wheeling with a second rig in my own opinion feels much more reassuring than wheeling solo with a winch. Plus there's many non-wheeling benefits to winches as well, like pulling a skid steer track that jumped off the idler wheel or moving some boulders or concrete blocks to access certain areas 😅 😅
This also happened before lockers were purchased and was a fantastic reminder of how terrible open diffs can be on wet mossy roads....
This thread is worthless without pics
Used it twice on Fordyce Creek " Sierra Trek " a couple weeks ago. Hard to see but the passenger front tire is wedged against the rock and the driver side is not making contact. I had to back up a bit but the trail dropped off the edge to a creek below. I kept the winch line connected to keep from going to far backwards and then meeting my maker. So to answer the OP question you never know when
When you need it, you need it... when you don't, you don't. If you don't have it, you cannot use it. Just my two cents. It was a godsend this spring out in the Red River Gorge area - but, I think an investment in synthetic line is smart (and one that I need to do). Lighter and safer.
Useful for more than recovery tooView attachment 638603
Wouldn’t it be faster to just tie a chain to the log and drag it where you want it? I don’t want to minimize the value of a winch, but before I had a front end loader on a tractor, I drug a lot of logs with a chain and truck or tractor and it seems like it was faster than doing it with a winch. I always had a winch on the front of one of my trucks, but for moving timber it seemed to be quick with a chain, especially if you had two people working together.
Reactions: Rickyd
The more I drive up and down the hill the more plants I kill and the worse erosion gets
Reactions: FarFire70
Great point! My timber moving was usually along fence rows around the edge of the pasture and meadows which when rutted in that area was not an issue.
Reactions: lBasket
Faster yes. If I was skidding with a tracked vehicle with no suspension...very predictable. Tractor too to some extent. I've had to recover at least four tractors neighbors have rolled over the years.
Jeep...out on a remote trail...limited communication or access to resources like additional assistance or first aid...slow and controlled and predictable with a winch is the way to go.
I will use a chain or choker as a lead on the log to avoid abrasion on my synthetic rope. Or a nylon strap...I have a few cheapies I don't mind sacrificing.
I've been slacking on wheeling for the last couple years. When I was wheeling more regularly, probably used it legitimately 3 - 4 times per year.
'legitimately' - If you could've use a recovery strap instead, it's not a legit use IMO. Legit is when you're stuck to the point where it's the correct tool to use. Many use it instead of a strap just because it's convenient. Most of the time a strap would suffice.
33s and a 3" lift I was winching 1-2 times per year. Always when I was solo, because I would rather pull rope than break stuff.
This year since going to 4" of lift and 35s I have not had to winch yet. And Im running harder trails along with the usual ones I had to winch on.
I went up in lift and tire size so I wouldnt wear out the bottom and it seems to be paying off 😄
Id be super pissed if I spent 10k and was still crashing all over :D
So then you should just wheel at the times when a strap will do, and not wheel when it won’t. Great, so any tips on how to identify the times when the strap it is not enough so you can know when to stay home?
