Washington Washington members that live to wheel
Haha they probably had no choice! Whether their sliders helped or not, who can really say?! Tiger's poor van probably didn't fair to well if they ran anything some of the interior trails and not the main loops. Lot's of trees not spaced generously for 1-tons and full size bodies.
Would've been so sweet to be there though. Fred passed me back in 2019 in the orange Dodge Tug Truck heading south from the Alaska trip. It was a highlight for me! I immediately messaged him on IG to see when he was stopping for fuel or something but he wasn't planning a drop for another 200 miles or more.
Did you at least get a wave?
  • Sad
Reactions: bbaldwin237
No 😞. I was riding with a friend at work and he got a call so we pulled off in a gravel area and while he talked I was just looking out the window and then pointed and said "That's Fred Williams." He was just like, "is that a friend of yours or something?" Not everyone gets it! 😂
  • Sad
Reactions: Apparition
I’m part of “not everyone.” Who is he?
Haha he's a former writer turned Editor in Chief of Petersen's 4Wheel and Off-road in the magazine days (@4xfredwilliams on IG and YT). Came up under guys like Rick Pewe. Eventually became the host of Dirt Every Day which later brought Dave Chappelle (@dirthead_dave on IG and The Dirthead Shed on YT). Dave is actually over in your area. Think he's in Mead but works at Diesel Power Products in Spokane.
I was the kid that didn't care about cartoons and sports. I watched all of the off-road and automotive shows and read the magazines (Petersen's being my all-time favorite).
https://www.motortrend.com/how-to/1410-1997-jeep-wrangler-mayhem-to-moab-part-3
In order to get ready for our annual trip to the Moab Easter Safari we stuffed 37-inch Pit Bull tires under our ’97 Jeep we affectionately call Tube Sock with only a 2-inch suspension lift. The goal is to build a strong yet simple little Jeep perfect for Moab’s red-rock trails. We figured 37’s would be adequate with just a trusty four-cylinder engine and enough gearing, but we really wanted to build this Jeep with as many off-the-shelf parts as we could find so that custom fabrication wouldn’t be required. In the end we did need to do some minor cutting and welding, but the majority of the install was still bolt-on.
The first iteration of Tube Sock was near perfect, it just worked. Always one of my favorites of his personal projects.
Well I’m not sure I’m going to make this run. I’m having issues with right rear shock rubbing the spring. The perch has already been cut back and it clears that but not the last bit of coil. Iv tried two different shock relocaters as temporary solutions and neither works with my aftermarket brackets. I don’t have time or resources to do an outboard right now. I’m toying with a couple ideas to piece it together for now just to go wheeling. We’ll see 🤷‍♂️
After my 4" lift and setting pinion angle, I cut off the old mounts, bought new mounts and welded them in at what would be stock orientation. No more clearance issues.
Welcome to my solution...let me know if I can help!
I have another aftermarket bracket that’s different than the one that’s currently on there. I’m just not sure putting it in the factory spot is going to clear. It’s seeming like I would have to angle it sticking out more than down..
I murdered a couple pairs of black maxes and decided any further effort was best spent outboarding.
Got a really slick solution for sucking up my exhaust. Got a few more parts coming.
Reactions: PG. and bbaldwin237
pic 1 you can see where it’s rubbing the spring. 2 and 3 are what I’m considering doing for now. It’s a hack job but may hold for now. I’m going to weld those little self made tabs to the outside of the existing bracket and it will place the shock farther away from the spring. Outboarding would be awesome if I had the time and money.
  • Sad
You forgot the pics
Oh and I had to cut the bolt out of the lower mount to remove it. Would a grade 8 work fine for lower shock mount or is 10.9 hardware required?
Reactions: macleanflood
Reactions: reddvltj
