Hey, I think I definitely just found the issue. I really wish I could post videos and show you a video because a picture won’t do it long story short I jacked up my rear axle and spun the tires clockwise and quickly before the rotation stops, I would rotate the tire counterclockwise, and I can literally hear click click click click click as if something in my transfer case or my transfer case to transmission is slipping
I’m glad you found it man.
If the shifter gives you a lot of issues just replace it with this
@macleanflood also just mentioned flushing your trans cooler. You can use compressed air (Very Carefully at like 5-10psi) or you can add fluid to the inlet and keep adding it till you see new fluid coming out of the outlet
