So I went to have my 99 SE (2.5L) emissions tested. They told me that the vehicle fails the test because OBD2 communications failed; they claimed they tried several different test setups (not sure what that means). I took it home, noticed the OBD2 pins looked corroded and dirty, and cleaned them with the little interdental brushes and MAF sensor cleaner. Took it back and it failed again for the same reason. I checked OBD2 port pins 4 and 5 (chassis and signal grounds) and both were 0.0 ohms. Pin 16 (battery power) reads 12.4 V.
Last year (first I owned it) it passed just fine. The battery was disconnected for a long period of time when I rebuilt the engine. I've only put about 58 miles on it since the rebuild. Is there some emissions readiness threshold that I haven't cleared? Would appreciate any advice. Should I just go to another shop and see if they can do the test successfully ($35)?
