A quick little project today - which of course means it took much longer than expected...
In the rig I run Polk DB522's in the dash and in the sound bar, backed up by a Bazooka sub in the console. All driven by a Soundstream Nano Amplifier under the steering column. It sounds fairly good, with great volume - but it's always sounded just a bit flat with the tweeters in the dash pointing at my knees. To lift the sound stage a bit, and improve the clarity, I've been giving some thought to adding some tweeters to the top of the dash.
After a bit of research here on the forum, and some DM help from
@DB04RedJeep , I found that several folks here have used Kicker component speakers to pull this off. So on a whim, I picked up these:
At about $200 from Amazon, not too big of a risk.
First up - out with the old:
Here are the Kickers next to the Polks on the left. The speakers are very similar, and the exact same weight.
The main challenge was getting under the dash to mount the tweeter pods (which came with the set) and fishing the wiring. That turned out to be fairly easy with just dropping the windshield and popping out the defroster grill:
After checking the clearance above the vent, I drilled a hole, bolted down the pod, installed the tweeter...
...and repeated on the other side:
The tweeters require a crossover to separate the high frequencies, and the kit comes with one for each side. I installed it behind the speaker with some adhesive Velcro:
With everything installed and wired I tested the new setup - and quickly discovered the tweeters were making a nasty, high-pitched, noticeable whine - even with the amplifier off. Not good.
After double checking all my wiring, and checking the gain on the amp, everything seemed correct. In frustration, I pulled out the crossover - and the whining stopped. Huh. Stuck it back in, and the whine was back. Something in that area was causing the interference. Good news.
Long story short, I found that if I installed the crossover in a vertical position in the exact location - as opposed to the original horizontal position - the whine did not occur. On the passenger side I had to relocate the crossover - actually not far from my original location - the get everything working quietly. Strange - but crisis avoided.
Then I was able to button everything back up and try out the new setup.
I've not spent a lot of time in there, but my initial impression is that it does sound much more clean and crisp.
A fun project for a Thursday afternoon.
